03-04 w/ MREV2 + Spacer
Old Aug 18, 2006 | 02:00 AM
Tobal's Avatar
Has anyone here with an 03-04 model done the MREV2 and Spacer mod combo on their cars. I have been reading that it tends to run lean with the given mod. I want to add the MREV2 and the spacer but dont' want to spend the extra cash on an ecu reflash or a piggyback system. Anyone here have any reviews?
Old Aug 18, 2006 | 02:02 AM
Calvin's Avatar
Overglorified Altima
i think youre going to run lean with mrev2 because its for revup engines..
you can get it but youll need a ecu reflash or whatever to get it to the right specs..
a spacer should be fine..
Old Aug 18, 2006 | 02:06 AM
abcquackyxyz's Avatar
+1 on the spacer
Old Aug 18, 2006 | 02:10 AM
Calvin's Avatar
you can also look for used mrevs since those were made for nonrev-up engines i believe
Old Aug 18, 2006 | 03:02 AM
zeroscythe's Avatar
please stop talking. The 03-04 comes stock with the mrev lower plenum. Its exactly what the mrev mod is... they take the lower plenum from the 03-04 and put it on the 05-06 6mt for a power gain.
The MREV2 is made as a mod for any G35 engine. It is actually modified enough to produce a larger power gain then the spacer on the non-rev up engine.
If you choose to go with the MREV2 and a spacer, say a 5/16 on a non-rev up engine, you will lean out your fuel. What you can do to avoid the $750 a reflash will cost you is, call split second and have them send you a new piggy back system they have for the N/A G.. it costs around $250 and whatever install costs... then all you have to do is find someone with the program and a laptop to remap the fuel correctly and you'll be fine.
When speaking with Motordyne, one of the guys there informed me that with an Intake, MREV and a new upper plenum their research showed that a fuel remap was not enough and you need to go with new Injectors and a fuel remap.
Old Aug 18, 2006 | 11:04 AM
Calvin's Avatar
im unaware of previous mrevs as i joined the g35driver after they were released so i was only exposed to the mrev2. thanks.
btw i did mention that i was uncertain about it.."i believe"
so anyway......
Old Aug 18, 2006 | 11:14 AM
k_hojnacki's Avatar
Agreed! You will most likely need larger injectors. Just with a Injen intake and a pop charger my car ran slightly lean and that was with the stock plenum. Add a spacer and a new lower plenum and you will need to add additional fuel to compensate. New mapping is "probably" not enough but as they say " you results may vary"
Old Aug 18, 2006 | 11:16 AM
Calvin's Avatar
"the MREV is simply a spacer with a lower plenum from the 280 HP engine. ...So if you have the 280 HP engine, all you need to do is install a spacer and you automatially have a MREV."
"If you already have a spacer, all you need to do is modify the lower collector and it will make more torque and more horse power! In addition to area under the curve, it will kick up the peak HP by about 4-6 HP."
The Mrev+ has been dynoed to show gains even on the 280hp engine..
So even though the 03-4 engines may already have the mrev...with the mrev+ they might see more gains..
from what i understand..nonrev-up engines want the mrev+ and spacer combo (if they want to go mrev at all)
Old Aug 18, 2006 | 02:26 PM
Memphis's Avatar
- the 03/04 G's lower plenum is the mrev plenum
- this plenum's front cylinder runners were modified to make the mrev+
- further modificaltions resulted in the mrev ++ which Tony renamed the mrev2
- go with the mrev2 if you do not have a spacer yet.
- i have the spacer and Tony told me that going with the mrev2 would only give me a few more hp's and as stated here a ecu mod is required.....only you can decide if the the cost to hp gain for the mrev2 & ecu mod are worth the $$$$$
Old Aug 18, 2006 | 02:34 PM
Jeff92se's Avatar
Red Card Crew
????????? I have never, ever seen a NA car able to max out it's injectors with only mild bolt ones. A reflash should be all you need. Unless you want more control and go with something like an UTEC etc...
Old Aug 18, 2006 | 03:06 PM
Rate G's Avatar
I have 03 6mt, took out motodyne spacer and z tube and replaced w/ mrev2 lower plenum. I did not want to add the spacer on top of the mrev2 because of threads re: lean burn. For me the mrev2 replaces the spacer and gives a stealth non mod look. Performs about the same, not as loud, the engine is more drivable in stop and go city traffic and but dyno feels like mrev2 comes in above 4k rpm.
Old Aug 18, 2006 | 03:31 PM
Sumlime311's Avatar
do you think you will need an ECU reflash if your just putting a spacer on it?
Old Aug 18, 2006 | 03:39 PM
Calvin's Avatar
ive heard of ecu reseting for just a spacer but not a reflash..
use the pedal method or unplug your battery for x amount of time i think are the most popular ways? idk
Old Aug 18, 2006 | 03:44 PM
Pedal method is better. I think its 7 hours for the unplug bat. method.
Old Aug 18, 2006 | 03:54 PM
Sumlime311's Avatar
what is the pedal method? or should I search it?
