Lost Power!!!!
Old Aug 27, 2006 | 02:24 PM
shooter's Avatar
It's not the critic......
Lost Power!!!!
Most threads here deal with gains (as they should), well this topic is of the opposite nature.
I installed the Injen SES on my G 1 year ago (still love the sound vroooom!). Recently I noticed an exhaust leak sound whenever I opened the drivers door and thought the gasket between the CAT and the exhaust was leaking. I jacked the car up today ready to adjust and tighten the flange connections and look what I found! Must be all that spirited driving .
What do you guys think? Repair (weld) or replace? Maybe use the Magnaflow as a replacement? Add the H pipe as well?
I wonder how much power I'm losing . I can't wait to get it fixed .
Also for all you Houston G riders, I need the name of a good muffler shop preferrably in the West/South West area (I live in Cinco Ranch). I want to get their opinion on welding this crack.
Thx Shooter
Old Aug 27, 2006 | 05:27 PM
cungkpham's Avatar
hey, that happened to me too! just weld it again.
Old Aug 27, 2006 | 07:19 PM
truplay8's Avatar
THE BATMOBILE
damn sorry to see.......like makaveli said they should be able to weld it
Old Aug 27, 2006 | 07:39 PM
crypten's Avatar
Same thing happened to me too with my Injen SES. I had a terrible leak coming from that same area. I had it a shop weld it, problem solved.
Old Aug 27, 2006 | 08:08 PM
Msedanman's Avatar
O.F. Administrator
A stainless system should be good for a long time.....get it re-welded...
C.
Old Aug 27, 2006 | 08:27 PM
2004v35's Avatar
re-weld
Old Aug 27, 2006 | 08:41 PM
shooter's Avatar
I will try and find a local shop and get it welded and post any butt dyno power gains .
I could really use some suggestions from the local group. Maybe I'll post over on 350Z as well.
Old Aug 27, 2006 | 08:58 PM
shooter's Avatar
What if the crack worsens and the 2 parts separate. Can the resonator fall and hurt my car or is there a pipe that extends inside the resonator?
Old Aug 27, 2006 | 09:51 PM
crypten's Avatar
I doubt it will get any worse. I drove around with mine like that for a good few months, no problems except for the annoying air leak sound, and maybe some power loss.
Old Aug 27, 2006 | 10:37 PM
shooter's Avatar
Thanks for the comment crypten
Did you also have the problem with the exit pipes not perfectly lining up with the cutouts in the rear bumper? Mine are positioned to the inside.
BTW AWESOME avatar!
Old Aug 28, 2006 | 09:19 AM
crypten's Avatar
I have heard about that issue, but I haven't had it. I had a rattle with the mid-pipe hitting the cross member, which sucked. I was told that you have to reposition the exhaust so it doesn't rattle, but that didn't help, so I found a work around. Try to had to tighten or loosen up the bolts until you have it in the right position.
Old Aug 28, 2006 | 09:59 AM
pdjafari's Avatar
dont most exhaust systems have some kind of lifetime warranty on its welds?? maybe you can get injen to hook it up with some $$ for repairs??
Old Aug 28, 2006 | 10:22 AM
crypten's Avatar
With the way Injen has responded to previous issues (ie: fiberglass), I doubt they would take the blame for a fault in the product. It would probably take a decent sized group of people to complain about something like this. If anyone wants to start up a list to submit to Injen, I would be the first to sign my name.
Old Aug 28, 2006 | 11:39 AM
pdjafari's Avatar
^^dude i just spent the past 4 min staring at your avatar!!!! skeet skeeet skeeeeet!!
Old Aug 29, 2006 | 12:11 AM
ISMSOLUTIONS's Avatar
Any reputable manufacturer will warranty its welds and workmanship for lifetime - if not - then why buy it...my 2 cents...Rick
