Poor Man's .10 Pop Charger!!
JWT POP will be here on Monday and I'm only poor in the sense that I can't have everything I want- A wife, 3-kids and 2-Mortgages will do that kinda of thing to you
What's the fun of having any car if you can't mess around with it??
if removing the power duct has heat concerns for some of you, you can use a foam weather stripping tape and outline the edge of the opening so that it creates a seal against the hood. I had to double up some to get the desired height but it makes a very good seal as you can tell by the impressions on the foam.
the install was cake... mounting the cone to the intake tube and wat not
was a piece of cake, but getting those damn weather strips on the heat
shield is a pita.
no wonder it's so damn cheap in price... most of the labor to assemble the thing is done by the consumer. lol
will run it tomorrow morning for a test drive.
in all honestly, i don't foresee much performance benefits from these
filters, but im sure the sound will be nice and deep.
You need to do some search in this furum before pull out a stupid *** mod like this. The power duct & the seal contacting the hood are part of the factory
Ram air duct, not a greta one but it does collect fresh air at speed. Removing it without getting a larger surface filter would only reduce power & gain some ricer sound.
Originally Posted by kenchan
i got mine today from www.ultimatez.com who are local to me.
shield is a pita.
shield is a pita.
+1 on that weatherstrip..i found out that you just have to put it on the oem plastic air duct...then take it off and put it on the heat shield...by that time the moulding is softer...
Originally Posted by aHero4Eternity
im not worried about the excess heat at all but im curious to see what this looks like. can you post some pictures? thanks!
not much to look at really, looks a little ghetto, but it only took a couple of minutes and a few cents to do. replicates that but enlarges the opening for fresh air to get in.
I've felt no loss of HP with my set-up, temps are running a few degrees higher, but that is about it. Sound is not ricer at all (for those who say otherwise). If anything it makes the stock sedan exhaust sound more 350Z like.
How does this sound? From my untrained eye it looks like the collection area under the power duct might work as a sound baffle.
