Coolent Bypass without Draining Coolent?
Old Dec 20, 2006 | 10:29 AM
Marshall2K's Avatar
Coolant Bypass without Draining Coolant?
I am going to perform the coolant bypass mod and was wondering if there is a way of doing it without draining the coolant first?
Old Dec 21, 2006 | 08:18 AM
cato's Avatar
SouthernComfort Moderator
You don't need to drain the coolant. Are you going to install Motordyne's Iso-thermal upgrade? For the Motordyne bypass, just cut the hose and install the bypass valve. A small ammount of coolant will leak, nothing to worry about.
Old Dec 21, 2006 | 10:18 PM
Hydrazine's Avatar
^^^ +1
You don't need to drain the coolant. That sounds like a Skunk procedure. Totally not needed.
Old Dec 28, 2006 | 11:39 PM
rcdash's Avatar
Just so you know - I got air bubbles in the system and didn't know it doing this. My heat would go cold when idling. It was fixed by bleeding the air out of the coolant system - but you should probably do this right away and not wait a year like I did (cause I didn't know till the weather got cold).
G35xdriver04
Nov 7, 2015 08:31 PM
hrdwirk1
Oct 2, 2015 06:34 PM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
G35CO
Sep 4, 2015 09:27 AM
