Loosing gas fast...
Old Mar 3, 2007 | 04:23 PM
hji1945's Avatar
Loosing gas fast...
After installing HKS, spacer, Plenum, z-tube, and popcharger.. I had reset my ECU.. And after that I feel like my car is running out of gas really fast.. Before I could went more than 300 miles before light came on.. Now it's hard to make it to 300 miles.. (I am talking about long high trips).. Is it because I haven't got tuned?? Making me worry about maybe my gas tank has leak..HAHA..
Old Mar 4, 2007 | 08:10 PM
GWord256's Avatar
Could be you just can't get your foot off the floor now with the new upgrades
That, and I hear that it'll take the ECU a few miles (several hundred) to fine tune the Air/Fuel ratio after a reset.
Old Mar 5, 2007 | 12:22 PM
hji1945's Avatar
Thanks for reply finally.. Hah.. I've driven more than 2000 miles now after reset.. And it still does that.. So.. I have no clue.. Oh.. And wierd thing is when my gas line goes all the way down to the bottom line I can keep drive around for while and the line will go back up littlebit.. So maybe my gas tank indicator is messed up.. Cause for while even I fill up my tank the gas line wouldn't go all the way to the top.. It will stay around the top first and then after few miles it will go beyond the top line.. Does this sound wrong? Or is this normal.. Cause before whenever I fill up gas it will go to the top instantly.. So.. I don't know what to do.. Oh.. And sorry about my grammer if there is anything wrong.. Heh.. Korean..
Old Mar 5, 2007 | 12:33 PM
filanj's Avatar
heavy foot = low gas mileage.
ps At the empty line on my car, I still have a quarter tank left.
Old Mar 5, 2007 | 07:44 PM
GWord256's Avatar
Gas gagues are never very accurate. I just fill my tank up when the light comes on and it usually takes 17.5 gallons. At that point it's pretty much on the last line.
Sorry I can't help you anymore then I aready did though.
Old Mar 5, 2007 | 08:16 PM
hji1945's Avatar
Ah... Ok.. I was just getting paranoid.. Cause I thought my gas was going down really quick than before.. But probably it's just my driving style.. So.. Thanks guys!!
Old Mar 5, 2007 | 08:30 PM
erdog's Avatar
I just topped off my gas to the point where it spilled and turned on my car and the gas level was half way between the top and the first 1/4 tank line. My guage almost never goes to the top.
Old Mar 5, 2007 | 09:52 PM
rcdash's Avatar
Never had this problem - gas gauge very accurate. When filled it goes to the top. Usually fill around 280 miles or so - all city driving and it eats up nearly 16 gallons. I'm lucky if I get 18 mpg, but my foot is on it all the time...
Old Mar 12, 2007 | 08:43 PM
hji1945's Avatar
I just came back from the dealer and they gave me new unit for the gas sender.. And now it seems work fine.. So.. Maybe you guys should take em in..
Old Mar 12, 2007 | 11:43 PM
Klubbheads's Avatar
throw the pop-charger away and put the stock intake on with k&n drop in and do a fuel injector cleaning into the valves and everything and u will notice better performance and gas mileage.
Old Mar 13, 2007 | 12:05 AM
liukai's Avatar
just so you won't feel bad, i got the same issues, with my gas gauge. pretty much, the light goes on when i have 5 gallons left. now, i know teh fuel light should pop on a few gallons before empty, but 5 gallons is more than it shoudl be. and this is after i had my fuel receiver (or i guess sender) replaced by the dealership. i just said screw it and jsut accept it for now.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
