Cold Air Intake
Originally Posted by DaveB
Fastest? No. One of the quickest coupes? Yes. An interesting tid bit is your coupe is only managing 100.4mph in the 1/4 mile with all those mods. My 03 sedan with a spacer and Z-tube is consistently seeing 99.7-99.9mph in the 1/4 mile though my ET is solidly .4 seconds off your pace. But only .5mph to .7mph from your coupe. From a roll, our cars would be neck and neck. I firmly believe your coupe would go 102mph if you replaced that POS CAI with the stock airbox. All that additonal intake piping length of the CAI is chocking the higher rpm performance of your VQ. I saw the exact thing with a CAI on my last VQ. My ETs were generally the same, but the CAI sucked a solid 2mph in the last 1/8 mile.
The stock intake setup, especially on the 07, is pulling in ambient air so it is truely a CAI. You would be kidding yourself if you thought the aftermarket could build a cooler CAI because nothing is cooler than pulling in ambient air and the OEM setup already does this.
1. dynoed the car
2. took the car to the track to prove negative results.
Then you cannot tell me im wrong. We will see when a company comes out with a product.
-sean
Originally Posted by Nismo G
That is the most retarded thing i have ever heard in my life. You think that a stillen air box is going to help my trap speed...my trap speed is affected by my gearing not my CAI. Right when i go across the 1/4 mile mark i am at the very very end of 3rd gear and switch into 4th right as i go across the line...4th gear on the 5AT is so long (if you haven’t noticed) i can do right around 140 in 4th gear. Maybe if i have a reflash to redline my car at 7200 vs 6700 i will trap higher speeds, maybe if i have different gears in my car i will trap higher speeds, but by replacing my CAI with a **** box...no my trap speed is not going to improve. Go tell whoever told you that information and tell them they are retarded. and your ET is only .4 seconds off...thats nearly a half second haha good luck catching up .4 seconds without a couple grand in mods....and your sedan is lighter than the coupe to start with
FYI, I tap the 3rd gear rev limiter just before the finish line (I'm talking mere feet before the finish). Interestingly, that would mean both of our cars are obtaining the same MPH at the end of the run and are technically make similiar power numbers. One major difference is your coupe is pulling about a .1 second quicker 60 foot which is good for about .2 seconds in the 1/4 mile. You're car is getting chocked by that CAI. If you only understand flow dynamics and the design of the VQ35 intake manifold, you'd see why that CAI is killing your MPH. It's too bad you won't at least give the stock airbox a shot at the track to see. You're also one of the few on this site that seems to believe that intakes do anything for the 1st gen cars.
As for "whoever told me that information", you're talking to him
I've tested every single type of intake known to man on my prior VQ. We're talking over 150 passes and over 10 dyno runs. I've tested the stock airbox, POP style, true CAI which tucks the filter into the fender (just like your CAI), and a hackerd verison of the stock airbox. Going by 1/4 mile passes and conversions to DA and considering 60', the hacked stock airbox made for the best ET and MPH. The G35 stock airbox to lightyears better than the stock airbox on the my old VQ30.
Stillen airbox? Huh? You'll never read me saying something as rediculous as that. Shall I post the dyno of the Stillen CAI gaining zilch in power over the stock airbox?
I've tested every single type of intake known to man on my prior VQ. We're talking over 150 passes and over 10 dyno runs. I've tested the stock airbox, POP style, true CAI which tucks the filter into the fender (just like your CAI), and a hackerd verison of the stock airbox. Going by 1/4 mile passes and conversions to DA and considering 60', the hacked stock airbox made for the best ET and MPH. The G35 stock airbox to lightyears better than the stock airbox on the my old VQ30.CAI have the advantage over stock air boxes at higher speeds sense they have direct air being pushed into them...nothing in the way of the filter (at least mine is setup like that) as your car goes faster the air is being rammed into the filter rather than your engine having to suck for it. The stock air box is going to have to “work” harder for the air IMO.
The reason i have the CAI still is because its obviously more efficient for me and i see better gains with it...im not going to put any "mod" onto my car that is going to slow it down.... except for rims or brakes something of that nature.
And one more question if the CAI didn’t add any power at all then how come im running numbers way below what I could when I was stock? You think my exhaust is giving me that much more power?
-sean
IMO this is how i view this whole issue...
I DON'T THINK YOU'LL GET ANYMORE GAINS FROM AN AFTER MARKET CAI. I THINK THE ENGINEERS AT NISSAN TWEAKED THIS MOTOR OUT. IF YOU DO GET ANY GAINS FROM A RESPECTABLE AFTER MARKET SUPPLIER IT WILL BE MINIMAL I.E. 1-2 HP GAIN. BUT WHAT ARE YOU SACRIFICING IN ORDER TO GET THAT 1HP GAIN? MONEY OBVIOUSLY, LOUD SOUNDING MOTOR, AND PROBABLY DOWN THE ROAD SOME MAS PROBLEMS WHICH NISSAN IS KNOWN FOR...
BUT AT THE END OF THE DAY IF YOU ARE A TUNER AND LIKE TO TAKE YOUR CARS TO SHOWS AND LIFT THE HOOD UP, I GUESS IT MAKES SENSE NOT TO HAVE A STOCK INTAKE SET UP FOR SHOW PURPOSE ONLY. TO ME THATS WHAT IT ALL BOILS DOWN TO..WHEN YOUR SHOWING OFF YOUR MOTOR DO YOU WANT IT DRESSED UP OR STOCK LOOKING? I PERSONALLY WOULD LIKE TO HAVE A NICE INTAKE SET UP, BUT I DONT WANT IT TO LOUD
I HOPE SOMEONE DYNOS BEFOR AND AFTER WHEN INSTALLING A CAI TO KNOW FOR SURE THE GAINS AND AT WHAT RPMS.
The stock airbox on the 03-06 cars can more air than the VQ35 can dish out. Shall I post the link of the 7 dedicated 350Z and G coupe race cars where 5 of the 7 cars are still equipped with the stock airboxes and the slowest cars were the ones with the aftermarket intakes? All these cars had significant NA mods like cams, intake spacers/manifolds, headers, etc.
Ahhh your at it again like usual.
That is why the Motordyne spacer for the REV up engine couldn't make the full power on a few cars tested with the stock intake including mine? The stock intake is good enough for a STOCK car, but one that has performance stuff on it, it just isn't enough.
DaveB is the notorious nay-sayer when it comes to mods for the G35. He will deny most of the mods that are for the G35/350z that they do not work without him actually testing them. If there was a dyno on any mod which there has been many that have proved gains then he will deny it and he will try to find one dyno that shows no gains like he threatend nismo with.
The guy is known for issues on maxima.org and my350z.com now. People hate him because of the way he trashes mods all the time.
The mods here known about his attitude, but just let him get away with it, so we lose valuable members on this site that have spent countless hours and money testing mods on the G35 and proved there were gains. They actually owned the mods unlike DaveB.
In another topic DaveB even said the 07 Exhaust is great and would not gain much 3-4 hp at the most from a Stillen Catback exhaust system. LOL! But he is going by what pictures he see's and considers that a fact with no testing.
what does that have anything to do with what i wrote????? you quoted me and talked about DAVE B?
-sean
It has to do with your last sentence about dynos. He will deny the dynos and say they are wrong.
hey fellas who cares what anyones says anyways if you want it and it makes you happy then just get it...apply this to everything in life as well lol
ohhh ok gotcha!!!!
I completely agree, the catch is when someone has a first gen. G and has never looked at the intake set up of the second gen and then based their opinion on experience with the first gen and we get ourselves in a bit of a pickle.
Nismo G - have you noticed that while the second gen is heavier and is roughly one tenth slower to the quarter mile then your car? I think Nissan did their homework when it came to tuning this engine, the simply bolt ons will not yield any sort of large boosts in performance.
Sean, what DaveB meant when comparing your traps speeds is that from a roll, a run between your car and his would be very close. ET's are a measure of traction, not power. Traps are much more indicative of power.
I can run 5 straight runs with the same traps, but have ET's that extend over a range of half a second. The car made the same power for each run, but traction will differ.
