Header HELP...please
Old Apr 29, 2007 | 04:31 PM
speedgeek's Avatar
Exclamation Header HELP...please
Please help me out. I had my Strup Headers installed at a shop and I’m hearing a leak, I take a look at the passenger side headers and I notice there are only 3 bolts and shafts on the top row of mounting bolts. Hard to describe, but if you look at the picture of the header below, see there are 4 holes on top. Shouldn’t there be 4 bolts , one for each hole? Thanks for any info you can provide.
Old Apr 29, 2007 | 05:22 PM
jjyellow's Avatar
Might want to take it back to the shop. Its hard to see on the passenger side, but most likely needs to be tightened more
Old Apr 29, 2007 | 07:37 PM
ISMSOLUTIONS's Avatar
It's pretty common that a re-torque is needed after initial install, and a few days of driving. The flanges get hot/cold and tend to 'warp' a little, so they need to be re-torqued to flatten back out.
Old Apr 29, 2007 | 07:48 PM
speedgeek's Avatar
Thanks for the quick reply. OK, I'll bring it back to get re-torqued. Should I be concerned about the three bolts on top instead of 4? it's the second bolt in on top from the right?
Thanks again
Old Apr 29, 2007 | 07:50 PM
You should be fine...it's just hard to see...
Old Apr 30, 2007 | 05:21 PM
speedgeek's Avatar
OK, thanks!
Old Apr 30, 2007 | 10:05 PM
j-champaco's Avatar
isnt there a gasket to prevent warpage? or did i just read that post wrong?
Old Apr 30, 2007 | 10:14 PM
Nismo G's Avatar
No, the gasket is there to "seal" the header to the engine and prevent leakage, only if its torqued to the correct specs though. After a few days it will start to break in and will need to be re-torqued.
A good example of this is your wheels after you take them off and you put them back on your supposed to tighten them to spec, and then re torque them a day later.
-Sean
Old Apr 30, 2007 | 10:45 PM
It's not a gasket thing - it's completely normal. Sometimes the bolts have to be re-torqued, sometimes not. It can really depend on the type of bolts being used as well. Also, it is possible that lock washers, etc, may be missing on a bolt or two and they loosened up....
Rick
Old May 3, 2007 | 12:47 AM
j-champaco's Avatar
you guys sure? i would ssume there would be SOME type of gasket ( whether steel / paper / copper / .. ) to disspate the heat ( throttlebody gasket / intake manifold gasket ).... i understand the re-torque, just " assumed" there would be a gasket - ever check the original headers? just a question - im going to look this up ( for my own knowledge - not trying to call anyone out or start a " THREAD FIGHT" ! lol ) james
Old May 3, 2007 | 12:50 AM
j-champaco's Avatar
-Sean
yea - youre right about sealing - but also warpage. if there IS a gasket - did the OP check his original headers? did he pull the gasket from them and reuse them ( exh. manifold gaskets can be reused )..has the OP popsted anything / update on this?
Old May 3, 2007 | 09:34 AM
Of course there's a gasket - whether one was used or not, or the notls jsut need torqueing...that's the mystery..
what happened othe OP on this???
Old May 3, 2007 | 09:43 AM
speedgeek's Avatar
Hi Guys,
Thanks again. I'm dropping the car off tonight to have both headers re-torqued. I’ll let you know tomorrow how it goes. Thanks so much for all the info.
Old May 6, 2007 | 08:43 PM
speedgeek's Avatar
Got them tightened, don’t hear the leak anymore. Thanks Guys.
I must say, “RASP SUCKS” I didn’t expect this much rasp with headers and metallic cats on a stock exhaust. Oh, well, waiting for the FI Group Buy.
Old May 6, 2007 | 11:59 PM
Cool...figured it was easy...
magnetism80
Jan 27, 2016 12:57 PM
alessandro
Oct 8, 2015 09:29 AM
lavtxa
Sep 21, 2015 11:51 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
