Will it fit???
Old May 4, 2007 | 01:23 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Will it fit???
I have a stillen Air box ,and i am currently using the filter it came with(K&N). I have a JWT pop-charger and i would like to know if that filter would also work with the Stillen box. The reason i would like to use the pop-charger again is because it is louder, and i need to clean one of the filters anyway. Let me know if you have tried this before?
-Tom
Old May 4, 2007 | 02:08 PM
ttrank's Avatar
Grocery getter
I don't think the base diameter is the same. The Stillen filter has a huge ~6" base.
Old May 4, 2007 | 02:18 PM
ct350g's Avatar
I have heard this works fine... I have the same setup coming this week....
Old May 4, 2007 | 05:44 PM
TURBOTOM's Avatar
a.k.a kleicoupe
For the record it fits, but I do not hear any difference between the two. The Stillen air box must block most of the noise from the filter.
Old May 4, 2007 | 08:32 PM
Andy2434's Avatar
It works just fine. No problems, here.
Old May 14, 2007 | 04:55 PM
ct350g's Avatar
I just installed my Stillen Cold Air Box with Popcharger..&...It fits!.... its basically the same filter, same velocity stack.... but the popcharger is open at the head of the filter.... the stillen is capped off- so I figured the popcharger would flow better.... I must say- maybe its the butt_dyno, but I feel a noticeable difference in throttle response with the Stillen/Popcharger over just the drop in K&N panel filter (running the z-tube for both)
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
