plenum spacer installation problem!!
Old May 29, 2007 | 09:38 PM
brown_fv's Avatar
hey guys i just finished installing my plenum spacer and when i turned on my car and let it idle for a bit and i realized there was some liquid "leaking" to the bottom of the car and there was a little bit of smoke appearing in the engine bay. i double checked all the hoses to see if they were in and they were. i tried it again and there was no liquid leaking anymore but still some smoke and a foul smell. i put the car in the garage because it is starting to get dark now...any ideas what the problem is and how i can fix this? i need to drive the car tomorrow
Old May 29, 2007 | 09:45 PM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
might be some of the fluids burning off. Let it run for a bit and keep listening for weird noises and keep checking the temp. If the smoke doesent go away in a few min the not to sure.
Old May 29, 2007 | 10:18 PM
brown_fv's Avatar
thanks, i found out i DO have a hose that wasn't put back at the back of hte plenum. i was able to put it back on but i couldnt put that thing on to secure the hose to the nipple. i guess ill just have to wake up early tomorrow and put the hose back on.
Old May 29, 2007 | 10:49 PM
brown_fv's Avatar
ok, well another question. the hose that i didnt connect to the back of the plenum, where does it come from? there was obviously some liquid that came out of it, so do i need to replace the liquid from wherever it came or what? from what i can see the hose connects to another hose and ends up coming from the radiator.
Old May 30, 2007 | 06:50 AM
g35rcr's Avatar
its the coolant that came out when you disconnected the throttle body
Old May 31, 2007 | 09:03 AM
Hydrazine's Avatar
It comes from the upper back side of the engine. Use a small mirror to find the hose nipple if needed.
Check your radiator resivior tank. Just keep it filled to the nominal level.
Tony
Gip
Aug 24, 2015 05:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
Ninjay16
Jul 20, 2015 01:21 AM
