Engine stalling with crawford plenum
Old Jul 11, 2007 | 12:19 AM
flyt89's Avatar
i just bought a used crawford v5 plenum. i installed it today but when i started it up it began stalling. Does anyone know what screws i need to get for the middle of the plenum. The stock plenum had 6 screws in the middle. i do not have screws in these holes. and the 2 middle holes in the crawford plenum are too long for the stock screws to fit. suggestions anyone?
Old Jul 11, 2007 | 12:28 AM
rookie's Avatar
You have a vacuum leak with those holes not sealed. Why didn't you received the bolts with the plenum? Try calling crawford to see if they can send you some new bolts.
Old Jul 11, 2007 | 12:30 AM
flyt89's Avatar
the seller didnt supply them. i kind of need those bolts tomorrow or else the car is stuck in my driveway.
Old Jul 11, 2007 | 12:36 AM
rookie's Avatar
Well, you can try the hardware store. Take the original bolts, and find longer ones. There are nylon washers that go with each bolt as well. If I remember correctly the bolts are staggered lengths.
Old Jul 11, 2007 | 01:18 AM
GreenGoblin's Avatar
The goblin resurrection
ya def a vac leak I though some had those holes welded up so that it could be smoothed out
Old Jul 11, 2007 | 07:54 AM
rpm06g35's Avatar
if you just put the top on bro and you didnt plug the 4 open hole you def got a vac leak. Your best bet is to take the top off. Take one of the 2 bolts you have in the center of the intake to ace hardware. Find an allen plug the same diameter and threadpitch and threadseal them into the lower intake from the top. Until then it will run but wont hold idle. good luck bro if you need anything else pm me mike
Old Jul 12, 2007 | 12:26 AM
flyt89's Avatar
got it running. went to the hardware store and got some bolts and thread lock thanks everyone.
Muski_G
Dec 1, 2023 11:11 AM
Terry_G35
May 9, 2020 01:39 AM
linedr89
Aug 17, 2015 05:11 PM
RA102223
Aug 15, 2015 09:24 PM
Terry_G35
Aug 4, 2015 02:38 PM
