Will a aftermarket 350z exhaust system fit on a g35 coupe. Thanks for your help I'am new to this site. Hope you can answer my ?
You will need an extension as the 350Z has shorter piping.
You can search some more info up if you like.
sometimes you may need to also have a shop chop the tips off and extend those (in addition to the other ~6-8" pipe extension).
this q. Has been covered many tmes before. Hero is right, besides the extension for the mid pipe, the z's tips will come up short on the g
The size difference in the cars is not only in the center section - but the rear as well. The tips are about 3-4"'s shorter on the Z. This is why HKS has adjustable tips and a center section of pipe to accomodate the different vehicles. Most others either make a system only for 1 model, or have two different part numbers and versions...like Fast Intentions, Stillen, Borla...etc.
Rick
Rick
