5/16 motordyne or aam spacer installation
Old Aug 25, 2007 | 11:53 AM
LSUmark's Avatar
Cool 5/16 motordyne or aam spacer installation
Hey guys.
Im a newish member around here just starting to seriously look into adding a few parts to my g.
I drive a 2003 g35 coupe (yes automatic..., i had no choice). I recently purchased a fujita intake.
I am looking into this 5/16 spacer from either of the above companies and want to know how easy/difficult the installation is on this product? Is it something someone with some limited installation expertise can do?
Ive installed a number of intakes on various cars and taken out spark plugs etc....but thats about it.
Additionally, is this a worthwhile mod if i am not going to reflash the ecu at this exact moment?
And furthermore, would test pipes or an ecu reflash be a better option after i have the intake and spacer?
Thanks guys, and sorry for the newbie questions...
Old Aug 25, 2007 | 12:17 PM
izmir41500's Avatar
G35driver Addict
Get the motordyne spacer. Install them at the same time since you have to remove the intake to install the spacer. They are both really easy to install. All you need is basic tools and a in-lb torque wrench.
Get a reflash after you finish your engine/breathing mods.
where are you located?
Old Aug 25, 2007 | 12:29 PM
LSUmark's Avatar
good deal will do
only problem with the ecu reflash is that my ride will have to be out of commission for a while since i have to send it off....
and im in lafayette, louisiana and baton rouge, louisiana. probably spend a bit more time in lafayette
Old Aug 25, 2007 | 12:31 PM
izmir41500's Avatar
G35driver Addict
just browse around and you'll find you have some options as far as engine tuning. osiris from uprev is a new one that looks promising.
Old Aug 25, 2007 | 01:03 PM
LSUmark's Avatar
yea wow that does look amazing
something to definately look into there
thanks for the info on the osiris!
linedr89
Aug 17, 2015 05:11 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
