Kinetix Intake vs Plenum Spacer
Old Aug 29, 2007 | 02:09 PM
gbabbitt's Avatar
Which option is more effective, replacing both plenums with the Kinetix or adding a plenum spacer? The Kinetix is a lot more money so I'm wondering if it's worth it.
Old Aug 29, 2007 | 02:18 PM
gary c's Avatar
Wooo, another new subject.......!
Depending on which year G35 you have I would go with the MotorDyne spacer. The 5/16" isn't visable and you can keep your OEM engine cover.
It's the best bang for your buck and probably one of the best mods you
can make for performance with breaking the bank!
Old Aug 29, 2007 | 02:19 PM
filanj's Avatar
Welcome to the forum. First off, If you locate the search tool on the main menu at the top of every page, you can find most of the answers you are looking for.
Read over these three threads I started way back in the day about this:
https://g35driver.com/forums/intake-exhaust/123283-1-2-md-spacer-kinetix-plenum-final-answer.html
https://g35driver.com/forums/archived-sales/122904-feeler-switch-kinetix-aps-crawford.html
https://g35driver.com/forums/showthread.php?p=1487784
I've tried both and I stuck with the Kinetix plenum.
P.S. There are two types of Kinetix plenums on the market. The V series and the SSV. The SSV is strictly for looks if you're not running forced induction and may even lose you HP if you're not FI. I am running the V+ series currently and love it. I've also had the V and the V+ definitely has improvements over the V.
-Tom
Old Aug 29, 2007 | 05:38 PM
G35Asian's Avatar
Either a plenum or plenum spacer will definitely gain you some power. It just depends on how much you want to spend and whether or not you care about under the hood looks.
Old Aug 29, 2007 | 06:48 PM
gbabbitt's Avatar
Thanks for the feedback. My intent is to gain power and increase the looks under the hood. I'd like to have a chrome plenum and z-tube with a half carbon fiber engine cover and Infiniti logo. With that said, should I just go with a spacer for the upper plenum or the upper and lower plenums, is adding the lower going to make a substantial difference?
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Terry_G35
Sep 10, 2015 08:17 PM
