Stillen Intake or JWT Pop Charger??
Old Dec 6, 2007 | 07:10 PM
xfuz1on's Avatar
as title states
Stillen Intake or JWT Pop Charger? Which one would be better?
Old Dec 6, 2007 | 07:15 PM
Calvin's Avatar
Overglorified Altima
Stillen, if you're looking for "performance" and insist on an aftermarket intake. The JWT intake has an inferior heat shield. That heat soak.
JWT, if you're just looking for sound. It definitely roars!
Old Dec 6, 2007 | 07:16 PM
ScubaSteve312's Avatar
Pop
Stillen if you like men
Old Dec 6, 2007 | 07:24 PM
MIA BlazinVQ's Avatar
brb getting cut
Stillen
Old Dec 6, 2007 | 08:19 PM
xfuz1on's Avatar
hmm, if you put on a stillen + Z tube. will the sound be affected? Like, will it give a deeper sound than stock? I have heard many say the jwt pop charger lacks quality but people purchase it for the sound. Can you hear a difference when you add the stillen + Z tube over stock? Hoping for it to give a "deeper" sound
Old Dec 6, 2007 | 10:21 PM
Beebo's Avatar
yeah you can its just not as loud as the pop charger... it has a nice roar...
Old Dec 9, 2007 | 04:57 PM
B GrAzi's Avatar
I have had both..i stayed with the stillen
Old Dec 9, 2007 | 05:01 PM
StreetChase's Avatar
Stillen FTW
Old Dec 9, 2007 | 05:24 PM
06g35meister's Avatar
sound or performace?
sound - pop charger
performance(+2hp, not very much) - stillen
best of both worlds? - stillen pop charger/ztube loud and high performance!
Old Dec 9, 2007 | 05:29 PM
Still2Slow's Avatar
I think the stillen is a bit nicer, but it costs more. I went with the JWT because I will be going FI soon, and I'll sell it. If I was staying NA, I would have went Stillen.
Old Dec 9, 2007 | 05:53 PM
citymunky's Avatar
I say Stillen also, the only reason that I'm not using it, is because I'm going FI also. So I got the K&N.
Old Dec 9, 2007 | 06:00 PM
Jason@Riverside's Avatar
The main performance will be from the "Z-Tube" Mod...
The cost of the Z-Tube has gone up so the Stillen Z-Tube is a much better option... Plus it is the correct length when on the G unlike the Z-Tube...
As far as the Pop Charger or Stillen Intake...
They both have a similar filter size.
They both have a similar Velocity Stack.
One is Blue, One is Red.
Both can use the same K&N Recharger kit etc.
The main differences...
The JWT uses a heat shield and weather stripping to keep the filter isolated from the rest of the engine room. Once in motion, it works great. Under stop and go conditions, the velocity stack (aluminum) will heat soak.
The Stillen has an enclosed urethane box similar to the factory abs box that keeps the filter isolated from the rest of the engine room. In motion, air is forced to stay around the air filter area like the stock filter. Under stop and go conditions, the velocity stack (aluminum) will heat soak but not as much.
There is a price difference. It may or may not be worth it to some. They both have the potential for the same power gains depending on the amount of heat soak the velocity stack has.
Old Aug 17, 2011 | 12:24 AM
TuCCii973's Avatar
@jason thats an awrsome review helpped me understand what i wanted a little more
Old Aug 17, 2011 | 12:29 AM
Xet's Avatar
Xet
Between the two, if you want an aftermarket intake go JWT. If you care about performance, maybe get a k&n filter and ztube and then leave your stock intake alone. Stillen is just a waste of money.
edit: wow bumped 2007 post >.>
Old Sep 30, 2011 | 01:35 AM
Speg80's Avatar
Going FI?
