z-tube/pop charger/drop in air filter questions
Old Mar 18, 2004 | 07:52 PM
Eurog35's Avatar
my g35 is stock, but can someone tell me what a pop charger is, how much it costs, and where i can purchase one...
i plan on gettin a ztube and a drop in filter for my car...
i dont wanna go the cai route, cuz of floods
Old Mar 18, 2004 | 08:33 PM
xxxmidget's Avatar
Re: z-tube/pop charger/drop in air filter questions
I just installed a ztube and the pop charger, and it makes a big difference at the higher rpm's both in performance and sound.
http://infinitipa.zoovy.com/product/PG353-1XCM8
since the g has an actual grill and a air duct to direct air flow into the the filter you dont need to have it so low like on the 350. I bought mine of the attached site and it was here within a week a z tube, pop , and clear corners for under 250 shipped. You will be happy with the results
Old Mar 18, 2004 | 09:33 PM
gte192t's Avatar
Does it provide anything below 4000 RPM, like a throatier sound or little bit more pep off the line?
Thanks!
-Chris
Old Mar 20, 2004 | 01:22 AM
ryoken's Avatar
Several of this site's sponsers sell the JWT Pop Chargers. Look in the "Items for sale - sponsors only" thread. I think one of them has posted pictures of the JWT Pop Charger and Z Tube.
The JWT Pop Charger is basically a blue cone filter. Does the same basic thing as the Stillen airbox -- replace the flat filter intake with a cone intake. Works with or without a Z Tube. They're a couple hundred bucks.
If you want the airbox or pop charger, you won't need the drop-in filter.
Old Mar 25, 2004 | 11:41 AM
mrman_3k's Avatar
What exactly is better about the Pop Charger over the standard air box?
Old Mar 25, 2004 | 02:38 PM
cato's Avatar
SouthernComfort Moderator
I can't speak of the Pop Charger itself, as I have the Stillen.
But both use a conical filter and a venturi ring. The conical
filter has more filter surface area versus the flat filter. This
means more filtered air coming in. I guess the Pop Charger
also uses a venturi ring. "The venturi ring acts as a velocity
stack, speeding up and directing the airflow into the intake
chambers, making more useable and noticable power."
So says Stillen.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Mar 26, 2004 | 07:35 AM
GLuvin's Avatar
The Stillen Pop charger or JWT Pop Charger do nothing to speak about below 3500. As your timing advances above 3500 you noticeably hear/feel the difference.
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
