How Much Horsepower???
Old Feb 17, 2008 | 10:40 PM
Mutedshark's Avatar
Smile How Much Horsepower???
Ok I am putting on all my Mods. Just what can I expect. I've read all the claims but just what is the truth? Putting on MREV 2, 5/16 ISO Copper spacer, JWT Popcharger,chrome Ztube,Fast Intentions Exhaust and Test pipes. All the claims add up to 43 RWHP on the low side. BS or not? Also I need input on the best RPMs to shift at if I was going for it! Any input will be welcome Thanx
Old Feb 17, 2008 | 11:00 PM
Texasscout's Avatar
Expect more like 20 to 25. Unfortunately you can't just add up all the claims that manufacturers make.
Old Feb 18, 2008 | 12:02 AM
Beebo's Avatar
^+1
Old Feb 18, 2008 | 12:18 AM
diablo1356's Avatar
the chrome z tube should net approx. 5 whp more than the regular z tube.
Old Feb 18, 2008 | 12:20 AM
Beebo's Avatar
how so?
Old Feb 18, 2008 | 12:27 AM
diablo1356's Avatar
because its just cooler...duh
Old Feb 18, 2008 | 01:10 AM
Beebo's Avatar
lol...
Old Feb 18, 2008 | 01:31 AM
mxracer1208's Avatar
...internet sarcasm... so hard to spot
Old Feb 18, 2008 | 02:46 AM
G37Rider92649's Avatar
You should get the pulley sets too After that you'll have on the bolt ons for the NA mods, besides that I had about everything you had with pulleys and I only had 254whp 247tq when I was NA, I suggest you do all that and then get a ecu-reflash (osiris uprev!), you'll be very happy with the performance gains.
Old Feb 18, 2008 | 03:21 AM
Klubbheads's Avatar
all those mods will yield about 10 peak HP and little bit midrange jump. With a dyno tune expect another 20-30 hp and nice midrange gain.
Old Feb 18, 2008 | 11:52 AM
Mutedshark's Avatar
Hard to believe just 10 HP for $2800. I'll send it all back if that were the case.I thought the ECU on the 06 was capable of reseting and learning for the mods. What is Osiris and how much $$ is that? I hope someone on here will just help me out and answer my original questions also.
Old Feb 18, 2008 | 12:01 PM
str8dum1's Avatar
i did all those NA mods and never once felt the money was justified via butt-dyno. but we all know louder= faster.
People on here say they can feel 5-10 hp difference, i sure cant
Old Feb 18, 2008 | 12:30 PM
jonnylaw's Avatar
You can't just add up manufacturer's claims of power gains and add it up and come up with a total expected gain. That's called ricer math.
When you combine all those bolt-ons, some things may negate others and you really never know how everything works out until its completed and tested.
If you get full bolt-ons, my suggestion would be that the tune would be the most important part in maximizing your gains.
Check out uprev.com for more info op on osiris op
Old Feb 18, 2008 | 02:02 PM
nismo240r's Avatar
x100000000
Old Feb 18, 2008 | 03:56 PM
Klubbheads's Avatar
It is hard to believe then i suggest u don't spend $2800. That is the type of car we have. U can take ur car to a professional tuner and with osiris they can extract more power from a BONE stock car than all the mods u mentioned.
My car is making its peak horsepower at 6200 rpm, I found out that shifting at 6600 rpm on the tachometer will give me the best results at the track, U will see a lot of people arguing this fact but those people most likely havent tried shifting at 6600 rpm and compare those times to shifting at 7300 rpm on the tach.
