Ran into something when installing plenum spacer
Old Apr 19, 2008 | 02:06 PM
lexusk8's Avatar
The install overall went fine. The 5/16" MD spacer and iso-thermal gasket fit fine with no problems, and no check engine lights. However prior to installing the iso-themal gasket, I've noted that 5 of the 6 manifold ports are dirty and oily on the surface walls, and only 1 port looks pretty clean. Is this normal, or is this something I should be concerned about?
Old Apr 19, 2008 | 02:45 PM
ModMe's Avatar
Wow, that is the dirtiest engine bay I have ever seen. Did your coolant tubes explode or something?
Old Apr 19, 2008 | 02:50 PM
citymunky's Avatar
I don't think that's normal, when I installed my MREV2, all 6 ports were oily/dirty.
Old Apr 19, 2008 | 02:56 PM
TIAN's Avatar
Hold The Line
Mine were clean.
Old Apr 19, 2008 | 03:40 PM
Hydrazine's Avatar
I can't say its a good thing, but its certaintly not uncommon.
Some engines do that and some don't.
G35VSHNG37
Oct 25, 2015 08:43 PM
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
