Mrev and spacer installation question
Old Jul 12, 2008 | 02:19 PM
HITMANVQ35's Avatar
I know the manual says to let the car sit overnight to let it cool completely but really how important is this step?
I drove it a little this morning, you think it'll be alright if I go ahead with the install 8 hrs later?
Old Jul 12, 2008 | 02:41 PM
SteveBlake's Avatar
You'll be more than fine, i drove mine 30 min to a shop and installed it right when i got there.
Old Jul 13, 2008 | 12:56 AM
Hydrazine's Avatar
You don't have to, but if you can, do it.
Old Jul 22, 2008 | 04:33 PM
jaedoggz's Avatar
the reason i believe they tell you that is because like all metals it expands when hot wand contracts when cold so if you do it when it is hot you might have to go back and retighten the bolts so there is not leaks, or so you dont strip the theads when it is hot due to the metal will be more soft the hard while heated up
Old Jul 23, 2008 | 01:53 AM
Hydrazine's Avatar
Its best to do it cold because of the different thermal expansion coefficents of steel bolts and the aluminum plenum.
Aluminum expands more than steel when the temperature is raised. And when the plenum is hot, the bolts are under more tension than when it is cold.
When you try to unscrew bolts from a hot plenum they can snap simply when you try to unscrew them.
I know, I've done it.
Old Aug 11, 2008 | 01:58 AM
astonv12's Avatar
Didn't want to start a new thread, but I just installed my 1/2" iso thermal spacer. Is it absolutely necessary to install the valve on the coolant hose? It was dark outside by the time I finished and I have work tomorrow morning. I just want to know if it is okay to drive around for a day without installing it or is it totally optional? Thanks. Love the spacer btw!
Old Aug 11, 2008 | 02:00 AM
BlueDevilBAMF's Avatar
I waited a few hours after driving... and I just went back and retightened the bolts after ~150 miles and then letting the engine cool overnight
Old Aug 11, 2008 | 02:32 AM
UR2EZ's Avatar
yea 8 hours is perfect
this step is VERY important, the lightweight aluminum expands and contracts CONSIDERABLY... the instructions have specified torque that would allow expansion once the engine is running. if you torque to 100 inch lbs on a hot engine, the plenum will come loose when the engine cools down!!!
Old Aug 11, 2008 | 02:55 AM
astonv12's Avatar
^ GUYS I brought this thread back from the dead. I have a new question(post#6). Stop answering the OP's question LOL.
edit: got your PM UR2EZ. My question is answered. Thanks!
Old Aug 11, 2008 | 08:18 AM
Hydrazine's Avatar
Originally Posted by astonv12
...Is it absolutely necessary to install the valve on the coolant hose? It was dark outside by the time I finished and I have work tomorrow morning. I just want to know if it is okay to drive around for a day without installing it or is it totally optional? Thanks. Love the spacer btw!
No, its not necessary to install the valve, but it is better if you do. Install it when you have time.
Tony
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
Soumilg
Jul 18, 2015 12:33 PM
