Need Help ASAP after Spacer Install
Old Sep 3, 2008 | 05:59 PM
s_saeed's Avatar
Just installed 5/16 iso-thermal spacer and copper t/b heater on my 04 g35 sedan 6mt. I have tried all the resets mentioned in the Motordyne install manual and am still getting a really rough idle and SES light. It idles very low and sometimes stalls out when coming to a stop and shifting into neutral. Once the car is moving it runs amazing and I can feel the additional power. Could I have messed something up in the install causing the above mentioned issues. I did clean out the throttle body with some T/B cleaner but did no move the throttle butterfly. I'm desperate now and any help you guys can provide at this point would be greatly appreciated. Thanks in advance.
Old Sep 3, 2008 | 06:00 PM
elayman's Avatar
check if you are missing a screw on your plenum.. it's not too uncommon to drop on inside i just hope you ddint haha
Old Sep 3, 2008 | 08:39 PM
nismo240r's Avatar
check all your vacuum hoses, make sure your MAF is plugged in properly. . .
Old Sep 3, 2008 | 11:13 PM
Hydrazine's Avatar
It sounds like you have a good size leak somwhere.
Big leaks are easy to find and fix.
Check for the leak and fix it. It has to be something big if it makes your car stall so it won't be hard to find.
Call me if you have any questions.
(661) 993-5111
I'll help out.
Tony
Old Sep 4, 2008 | 11:15 AM
elrooko's Avatar
Did your oil filler funnel (rubber housing around the oil cap) get stuck inbetween the lower and upper plenums? I did that, just have a look.
Old Sep 4, 2008 | 04:28 PM
mtodde's Avatar
I had some issues too...I disconnected the battery, unplugged the throttle body connector then reconnected everything and did the resets...I've gone 500 miles since without an issue...knock on wood.
Old Sep 5, 2008 | 09:10 PM
s_saeed's Avatar
I did a quick run through and everything seems to plugged in ok. I'm going to disconnect the battery and throttle body connector like mtodde mentioned tomorrow and try it again. It's getting real frustrating now. The car idles but its rough and it will occasionaly stall out when coming to stop. Do you guys have any pointers on how I can check if I have a leak somewhere??
Old Sep 6, 2008 | 11:45 AM
Hydrazine's Avatar
Run your hand along the outer circumference of the plenum sealing surfaces. If you run your hand over an area that has a leak you will hear a change of sound as you run your hand over it.
Another possibility is you may need a throttlebody idle calibration reset. Try that.
And trouble shooting over the phone is a lot faster/easier than over the keyboard too.
Old Sep 6, 2008 | 12:52 PM
elrooko's Avatar
Did you use a torque wrench to tighten everything down? Maybe your ztube is leaking. Did you reconnect the air hose on the bottom side of your intake?
Old Sep 6, 2008 | 05:59 PM
s_saeed's Avatar
Problem Solved!!! I started it up and within 2 mins I could tell the throttle body gasket was leaking between the trottle body and the copper heater gasket. I just took the copper heater part out and put it back together, no more leak! I'm gonna get a new gasket and try to put the copper heater back in before winter, i'm gonna need it, it gets pretty cold up here in Toronto. Thanks for all your help guys, I really appreciate it.
jsimonk
Dec 22, 2023 03:49 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
Soumilg
Jul 18, 2015 12:33 PM
