Fast Intentions install..Help Please
Old Sep 7, 2008 | 06:14 PM
valetkyle's Avatar
How the F$*K do you get the mid pipe in? I've tried everything. I bought it used, are there instructions anywhere?
Old Sep 7, 2008 | 06:21 PM
UnluckyCharms's Avatar
Elaborate more, please. The old midpipe and Y-pipe should unbolt with a little muscle (and PB Blaster), and the new midpipe bolts up to the two pipes that replace the factory Y-pipe. It's a very straight-forward install.
Old Sep 7, 2008 | 06:26 PM
valetkyle's Avatar
the FI mid pipe. I can't slide it in. Do I need to remove that underbody brace?
Old Sep 7, 2008 | 06:28 PM
You don't need to completely remove it, but you need to pull out a few of the bolts to allow it to flex down.
Old Sep 7, 2008 | 07:59 PM
valetkyle's Avatar
Awesome..thanks! Just finished. I need test pipes bad!!!
Old Sep 7, 2008 | 11:07 PM
jserman's Avatar
yes TP's with the FI exhaust is the sex....thats what I am running
Old Sep 7, 2008 | 11:51 PM
valetkyle's Avatar
What TP's are you running?
Old Sep 8, 2008 | 12:41 AM
Skaterbasist's Avatar
Retired SuperMod
Yep. F.I Exhaust + F.I Res. TP's FTW
Old Sep 8, 2008 | 01:51 AM
jserman's Avatar
the FI resonated one's
Old Sep 9, 2008 | 06:35 PM
A.H's Avatar
A.H
have the same setup and it is GODLIKE
magnetism80
Jan 27, 2016 12:57 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
