Do I need new gaskets?
Old Sep 7, 2008 | 08:34 PM
RedondoG's Avatar
I'm about to replace my stock cats with HFCs.
Do I need new gaskets where the cats attach to the headers and the Y pipe, or do I just use the old ones?
Old Sep 7, 2008 | 10:21 PM
Skaterbasist's Avatar
Retired SuperMod
For the header-cat gaskets, just reuse the OEM Nissan gaskets. They are "metallic".
Usually, aftermarket HFC will come with their own gaskets for the HFC/Y-pipe side (iirc, 2 bolt gasket).
Do you have the stock exhaust? The OEM gaskets look pretty good.
Old Sep 7, 2008 | 10:58 PM
RedondoG's Avatar
my HFCs are used and didn't come with gaskets...?
Old Sep 8, 2008 | 12:28 AM
Chef-j's Avatar
I will replace them to new. It's only few bucks at local muffler shop.
Old Sep 8, 2008 | 12:29 AM
Barzten1's Avatar
Id replace for $12 to not worry again.
Old Sep 8, 2008 | 12:30 AM
Scrooge's Avatar
You just want to use new gasket incase of any leaks
Old Sep 8, 2008 | 12:36 AM
gary c's Avatar
You have two choices....!
The OEM gaskets are totally reusible, I've had mine off and on several times
with 4 different systems....Or if you need to spend the $ drop by Nissan
parts counter and get a new set. (cheaper than Infiniti)
Gary
Old Sep 8, 2008 | 12:40 AM
Retired SuperMod
Gary
Exactly. If you happen to have all of the necessary OEM gaskets (2 bolt & 3 bolt gaskets), then definately reuse them.
If you happen to other aftermarket gaskets already in place, chances are, they are already cooked.
Old Sep 8, 2008 | 10:56 AM
RedondoG's Avatar
thanks for the input guys..
Old Sep 8, 2008 | 05:41 PM
damafuka's Avatar
Gary
so they are the same exhaust gaskets? i went to nissan today to get stock exhaust gaskets and they said that they didn't know if they were the same as the infinitis
Old Sep 11, 2008 | 11:18 PM
OCG35's Avatar
re-use the OEM that are on there.
Old Sep 12, 2008 | 09:56 AM
Hydrazine's Avatar
Gary
+3
The stock gaskets are the best. Much better than the aftermarket gaskets typically supplied with test pipes or cats.
I've reused mine probably about 50X with all the development testing I've done.
Still no leaks.
Old Sep 16, 2008 | 03:14 PM
damafuka's Avatar
I can't... they are gone. I need new ones cause i might be getting rid of the g and need new gaskets for the stock exhaust. i'm currently running hks
Old Sep 16, 2008 | 03:23 PM
OCG35's Avatar
if you have a dealer near you, you can picked them up from the parts dept.
Old Sep 16, 2008 | 07:19 PM
damafuka's Avatar
will the 350z gaskets work
