Z tube install question
Old Sep 14, 2008 | 04:18 AM
n15m0's Avatar
Hi guys,
finally installed my Ztube yesterday, question is, I've seen quite a few installs and why does my Ztube have the extra piece that hooks to the plenum on top? (circled in red)
The A/C vacuum line was underneath which was a bit tricky but I managed to fit it back on the intake pipe.
2nd pic is my factory V tube
Did a bit of a squirt around the neighbourhood after install and definately sounds a lot better around the 3-4K rpm!
Can't wait for the HKS muffler.
Old Sep 14, 2008 | 08:54 PM
stradaONE8's Avatar
Just installed mine on my 06 coupe from an 06 Z just this weekend. It did not have the extra piping line. Not sure what that is.
Definitely sounds better than the stock setup.
Old Sep 14, 2008 | 09:11 PM
EL-EE-ES's Avatar
i dont recall having that part...but i do love the sound
Old Sep 14, 2008 | 09:21 PM
envy-ths's Avatar
wait till u get a stillen intake 2 go with it talk about a monster sound.
Old Sep 14, 2008 | 09:31 PM
sloppymax's Avatar
guessing this is not US spec G35 since the master cylinder is on the left. i would guess the tube is an emissions difference.
Old Sep 14, 2008 | 09:38 PM
n15m0's Avatar
Its a JDM V35 and the Z tube is out of an AUS Spec 350z. Do your factory G tubes have that cannister hooked to the bottom?
Old Sep 14, 2008 | 09:51 PM
sloppymax's Avatar
Correct. The G tube has the resonator chamber on the bottom. The Z tube does not, hence the slight increase in sound. However, both the Z and G have the breather tube underneath.
Old Sep 14, 2008 | 10:33 PM
n15m0's Avatar
So would it be safe to assume that piece of plastic on the Z tube is the resonator chamber for the Z? Weird how USDM models don't have it...its a pain coz now I can't screw in that last screw on the top right hand corner of the engine cover.
Old Sep 15, 2008 | 07:00 AM
sloppymax's Avatar
I would only assume that if the chamber it goes to is closed. If it feeds into the plenum or anywhere else then it is acting as a breather. I cannot tell by the picture if it actually leads into something or it just stops near the throttle body.
Th611
Oct 27, 2015 03:48 PM
w4kj4k
Engine - Intake/Fuel
Oct 7, 2015 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
