Question about Wheel horse power
Old Oct 5, 2008 | 03:20 PM
eric1111's Avatar
How much is 6 wheel horse power. Is it about 15 hp from the engine. New to this stuff trying to learn a little. Sorry for all the uestions. Thanks.
Old Oct 5, 2008 | 03:28 PM
uf20wop's Avatar
it depends on the drivetrain loss and other factors
roughly about 25% for Gs i think
Old Oct 5, 2008 | 07:08 PM
mIKE's Avatar
15% is reasonable accurate on the G.
6WHP is within the error range on a dyno.
Old Oct 5, 2008 | 07:23 PM
eric1111's Avatar
So how would i figure the actual HP is with those %. Thanks
Old Oct 6, 2008 | 01:10 PM
Q45tech's Avatar
Unfortunately driveline friction losses are not level and vary with rpm and all fluid temperatures plus tire temperatures.
So it is impossible to state a specific friction loss [ as a %] without specing an rpm and temperature for every variable.
Most approximations are wishful ranges that assume the publish numbers are correct when engines actually vary by +- 5 HP and lb/ft from unit to unit when brand new.
The factory actually measures 5-20 units and gives either best peak or high average.
Old Oct 6, 2008 | 01:12 PM
uf20wop's Avatar
the only real way to get a car's actual WHP is to take it to a dyno.
and even then, there's still small variables that will make small differences.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
