Valve Cover Gasket Leaking
Old Nov 11, 2008 | 11:44 PM
msburton's Avatar
I need to replace my passengers side valve cover. What other gaskets are necessary. The shop manual says that I should replace both intake gaskets. Whats your opinion on this, are they re-useable?
Anything else I should know?
Thanks
Old Nov 11, 2008 | 11:48 PM
rookie's Avatar
Should be fine reusing them, not much money to replace though. It would be the lower and upper plenum since it should come off, throttle body if you take the throttle body off the upper plenum.
Oil the valve cover gasket before putting it on, rtv the front. Is it leaking from the spark plug hole?
Old Nov 12, 2008 | 08:08 AM
uf20wop's Avatar
i thought you had to buy new valve covers for these when the gasket is leaking
could be wrong though
Old Nov 12, 2008 | 10:56 AM
msburton's Avatar
That would suck! I found the gasket at the Infiniti dealer parts web site.
Old Nov 12, 2008 | 12:23 PM
rookie's Avatar
Spark plug seal is built into the valve covers. If it is leaking there a new vavle cover will be needed. Perimeter leaks would be the gasket.
Old Nov 12, 2008 | 02:00 PM
uf20wop's Avatar
ahhh ok, i knew there was something funny about it
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
TNRocker
Sep 21, 2015 08:36 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
UT G35
Sep 3, 2015 03:58 PM
