Question about my exhaust Setup Fuji exhaust/JIC y-pipe
Old Nov 19, 2008 | 12:18 PM
neo_rambo's Avatar
I noticed that I have rasp at high rpms on this setup doing further research I found out that the JIC Y-Pipe has Inlet Diameter: 60mm (2.36") and a Exit Diameter: 80mm (3.15") My fujitsubo exhaust has a 3.0 diameter. I thinking the y-pipe is causing the rasp and turbulence. Am I right? What is the diameter of the stock cat outlet? Would the rasp go away if I get a fuji y-pipe or megan. I searched for a solution didn't find anyone with the same problem.
Old Nov 19, 2008 | 02:13 PM
Hydrazine's Avatar
Try the resonated XYZ. Rasp will be terminated.
Old Nov 19, 2008 | 03:06 PM
neo_rambo's Avatar
The motordyne XYZ? I have stock Cats and headers. The fujitsubo is very quiet to begin with. Will the xyz quiet it down more?
Old Jun 1, 2011 | 04:51 PM
G&Z's Avatar
G&Z
I have d fuji y pipe and mid pipe back setup with no rasp. I just measured my fuji y pipe inlet diameter and it appears to be around 2.25 and exits @3
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
