Header Install
Old Nov 29, 2008 | 01:46 PM
LightsOut's Avatar
SIETESG
so someone has steped up and decided to do this mod. when done post dyno results. very intrested in final outcome
Old Nov 29, 2008 | 08:43 PM
molidor01's Avatar
Well as Dave said they are OEM Headers off a 08 350Z. Compared the cost of aftermarket headers, I save few hundred dollars. Nissan made the changes to the parts(Y-pipe, air box, switch to headers vice a manifold) for for a reason. I should get more bang for my buck going this route, instead of buying all aftermarket parts. DaveB stumbled on to something and why not upgrade our older VQ's with some of the newer VQ goodies. I'll keep you all posted.
Old Dec 2, 2008 | 10:57 AM
CreativeDesignZ's Avatar
awesome, well let me know how it works out for ya!
Old Dec 7, 2008 | 08:47 PM
molidor01's Avatar
ok. next update. As suggested from someone on 350Z.com, i purchased an exhaust manifold gasket for the a 03 VQ35DE and match it to the 08 350Z headers. It matches up perfectly. The 08 headers will require 2 additional holes drilled in the center flange. The 08 header has 6 bolt holes (2 on each end/2 in the center) whereas the 03 exhaust manifold has 8 (2 on each end/4 in the center). There's plenty of room on the flange to drill the additional holes. I went to my local nissan dealer to purchase the gasket...$59.00..F that..Auto Zone sold a pair of FEL-PRO gaskets for $9.00. Wonder what the infiniti dealership charges?? Will try and get the headers installed over the holidays.
Old Dec 8, 2008 | 12:03 AM
DaveB's Avatar
Definitely get the OEM gaskets. The OEM ones are designed correctly and for longterm usage plus I've NEVER had an OEM exhaust gasket fail, but I've had lots of aftermarket "OEM equipment" gaskets fail. When you're digging into a project like this, it would be wiser to spend the extra money now rather than risk having to replace the gaskets in 5K miles. Try Infinitipartsusa.com for the gaskets ($33 ea).
As for the holes, hold off for now because the OEM DE manifolds only use two studs/bolts in the center flange (confirmed with the FSM). The extra two holes on DE flange have no purpose and I believe the configuration of the studs from DE to HR are the same across the entire flange.
Old Dec 29, 2008 | 01:49 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by Canadian
Don't do it...its a little more than a PITA.
haha, Jordan, what if he has me there helping him out with the install? I've always wanted to try a header install on our cars!
-GP-
Old Jan 10, 2009 | 09:39 PM
molidor01's Avatar
Header Install
Finally found a set of 08 350Z headers. Will start the install shortly. For you folks who want to save a couple of bucks, here is what I've spent so far:
08 350z Headers: 120.00
08 350Z Cats: 200.00
Gaskets/misc parts: 75.00
Total: 395.00
Did a comparison with some after market parts:
DC Headers: 769.00
Stillen Cats: 515.00
Total: 1284.00
Total Savings: 889.00
Definitely not cracking on the after market parts, but if I can get the same performance out of OEM parts and save a few bucks for other things, why not!! I'll keep you posted.
Old Jan 10, 2009 | 09:44 PM
pattyskin's Avatar
Total: 395.00
DC Headers: 769.00
Total: 1284.00
That's a pretty good price for the OEM cats... When my car got damaged and needed the cats replaced they were 749.99. Fortunately it was all insurance payment.
Old Jan 11, 2009 | 09:46 AM
str8dum1's Avatar
prolyl same performance bc aftermarket headers dont add anything..
you'll be good to go!
Old Jan 11, 2009 | 02:26 PM
OCG35's Avatar
that right headers with cams do.
not cost effective though.
with or without cams, car should be tuned after headers are installed.
Old Jan 11, 2009 | 02:28 PM
Total: 395.00
DC Headers: 769.00
Total: 1284.00
sweet deal, and with the DIY install and my help, it'll be even cheaper! haha, lemme know when you wanna give it a go on the install and i'm there!
-GP-
Old Jan 11, 2009 | 10:31 PM
molidor01's Avatar
PM me your number and we'll set a date.
Terry
Old Jan 25, 2009 | 01:08 PM
Dsskyline's Avatar
Terry
can you post a pic of these headers and where did you get them?
Old Jan 29, 2009 | 12:25 AM
molidor01's Avatar
Header Install
Take a look through this thread and you will see the headers: https://g35driver.com/forums/intake-...-2003-g35.html. I bought them off of My350Z.com
Terry
Old Mar 3, 2009 | 10:06 AM
  #30
sillief00l's Avatar
Any progress on this effort?
