Fast Intentions Exhaust sitting too low??
Old Dec 16, 2008 | 04:24 PM
ShanesG's Avatar
Ok so i installed my FI exhaust on sat. and i keep looking at all the pics i can find and they all appear that i installed it correct, but to me it seems as if the "Magnaflow Muffler" on the mid-pipe is hanging too low, i mean i and like 2" off the ground bt the muffler is even lower it seems
heres a pic:
Anyone else with FI exhaust can you post pics or check your exhaust for reference?!?!?
Old Dec 16, 2008 | 04:26 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Does not look that low to me, I'm sure someone with an FI exhaust can chime in.
Old Dec 16, 2008 | 04:34 PM
UnluckyCharms's Avatar
The Magnaflow X pipe should be about even with the crossmember under the car (the one you have to loosen to slide the midpipe in). I should have my car on a lift this Saturday, and can take a peek then.
Old Dec 16, 2008 | 04:35 PM
ShanesG's Avatar
It's less than 2" off the ground haha
Old Dec 17, 2008 | 11:59 AM
elrooko's Avatar
heres a pic:
I Have it on my coupe. That is definately not right. Are you sure you don't have something installed upside down? My car is in storage right now but from what remember, miine is tucked up under the oem cross brace so it is definately not visable when you look under the car.
Old Dec 17, 2008 | 12:28 PM
ShanesG's Avatar
hmmm, i installed it exactly how it's pictured on the FI site, maybe i'll try switching the 2 "S" pipes off the cats
Old Dec 17, 2008 | 12:30 PM
FastIntentions's Avatar
From the pictures it looks like you bought it used. I could be wrong and if I am then please correct me. But if I am right, I am going to assume that you did not get the instructions with it. It could be installed wrong. Please call me and I can walk you through how it should be step by step. But it does look too low...
Thanks, Tony
(818) 882-2788
Old Dec 17, 2008 | 12:34 PM
ShanesG's Avatar
^Yes i got it used, is there a PDF or something you would be able to send me. Since i'm at work right now...or even through PM???
Old Dec 17, 2008 | 12:41 PM
GreenGoblin's Avatar
The goblin resurrection
Shane you fail at installs but congrats on the exhaust
Old Dec 17, 2008 | 12:43 PM
ShanesG's Avatar
^No way, i'm pro...if anything is wrong its just the 2 "S" pipes that come off the cat, cause the mid cant be installed any other way!
Old Dec 17, 2008 | 12:52 PM
I bet they are mixed up kinda like your vaccum hose incident ......
Old Dec 17, 2008 | 12:55 PM
ShanesG's Avatar
^lol oh boy that was funny!!!
Old Dec 17, 2008 | 12:57 PM
Boston's Avatar
Shane, talk with Tony or get the PDF if he has that format for the intall guide. I have the exhaust and mine is above the cross member.
Old Dec 17, 2008 | 12:59 PM
O.K. I took another look at the picture and it looks to me like one if not both of your S Pipes are backwards. The correct way to have them installed is the driver side S Pipe needs to have the single dot on the flange facing forward, inboard and down. The passenger side needs to sit with the 2 dots facing forward, inboard and down. If this is not what you see then the two S Pipes are installed wrong...
Tony
Old Dec 17, 2008 | 01:03 PM
ShanesG's Avatar
where would those dots be located???
