Exhaust question
Old Dec 17, 2008 | 09:29 AM
lexusk8's Avatar
Exhaust question
I'll be installing a new exhaust this weekend, and I have a question regarding the removal of the stock exhaust. Since the exhaust is hung by the hangers (all 3 of them) at the rubber bushings, do I need any special tools to pull the hangers out of the bushings? What's the procedure to easily remove the exhaust? I've heard it takes less than 30 min to remove and install the exhaust.
Old Dec 17, 2008 | 09:52 AM
Mustang5L5's Avatar
Unbolt the exhaust, spray a little WD-40 inside the rubber hangers and pull it off.
Sometimes the rubber is a little stubborn, so you'll need to shoot the wd-40 inside the grommet and work it loose
Old Dec 17, 2008 | 10:06 AM
Joe_Camel's Avatar
+1
I replaced my stock muffler with an HKS rear section and it was super easy, like stang said the grommets are the only stubborn part. Nothing special needed, just muscle.
Old Dec 17, 2008 | 11:47 AM
g35freak86's Avatar
+1 to what everyone said. I've replaced the whole exhaust on my sedan (except y pipe) and onlu advice you need is to spray the living crap outta the bolts with rust remover or wd-40 and let sit for at least 10 minutes. It will make the job go MUCH easier.
As far as removing the rubber gaskets. Once the exhaust is off the car, you are able to work with the bushings much easier and just shimmy them off. Using wd-40 will help a lot too.
Old Dec 17, 2008 | 01:12 PM
lexusk8's Avatar
Thanks for the prompt and detailed answers guys. I have cans of PBC Blaster and WD-40 so I'll make sure to use them come time to remove the exhaust. I look forward to what will hopefully be a relatively easy install job this Saturday. The exhaust going in will be the HKS rear section (paired with the 05-06 sedan midpipe already on the car) so it'll be time to open the sound on the G more!
Old Dec 17, 2008 | 01:37 PM
ttrank's Avatar
Grocery getter
PBC lube is awesome for stubborn bolts.
Have fun with the install.
Muski_G
Dec 1, 2023 11:11 AM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
