good exhaust to use with test pipes?
Old Feb 24, 2009 | 05:25 AM
jdm-v35's Avatar
I just installed unresonated test pipes and am having some rasp. also the way my exhaust is angled it hits my veilside rear lip.
Looking for a new exhaust system that would work well with test pipes. would like to try and eliminate as much rasp as possible even though i know it can't ever be really fully eliminated.
Ive tried a few different setups so far and am looking into other options.
Current setup:
unresonated test pipes, custom 2.5" true dual w/ x pipe and resonators using apexi N1's.
previously had xo2 and HKS custom single 3" setup with xerd headers. this had rediculous rasp so i switched back to stock headers.
options I was thinking of using are topspeed pro n1 since it has silencers. also looking into nismo or possibly xo2 again.
any suggestions would be greatly appreciated.
Old Feb 24, 2009 | 06:10 AM
coup de grace's Avatar
Well the first thing you want to do is probably get resonated test pipes. As far as the exhaust, you're not going to see much of a different between the Top Speed and the Apexi. All N1 exhausts are pretty much the same. If you want a silencer, you can buy one separately, there's not need to get an entire exhaust for just a silencer.
Old Feb 24, 2009 | 01:19 PM
jdm-v35's Avatar
well also part of the problem is the apexi is buring my veilside rear lip due to the slight angle. the exhaust gases are blowing agaisnt it.
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
andresito7
Aug 1, 2015 04:53 AM
mjfenix
Jul 14, 2015 10:37 PM
