plenum spacer install question
Old Apr 16, 2009 | 01:27 PM
uf20wop's Avatar
if i disconnect the coolant lines in order to remove the upper half of the plenum does this mean i'm going to have to bleed the coolant lines after the spacer install?
Old Apr 16, 2009 | 01:52 PM
SxExCx's Avatar
no, just a few drops will come out from the TB lines, nothing else is needed
Old Apr 16, 2009 | 03:04 PM
uf20wop's Avatar
oh ok, i didn't know if disconnecting the lines would cause air to get trapped in the system and then lead to overheating problems.
thanks
Gip
Aug 24, 2015 05:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
Ninjay16
Jul 20, 2015 01:21 AM
