stillen high flow cats with stock exhaustand pipes
Old Apr 21, 2009 | 12:07 PM
crazeejitt's Avatar
so would the http://www.g35parts.com/9083/osc/pro...697d8352c08cfb
work with stock pipes and stock headers and exhaust etc... I am wanting to upgrade the cats now and later on down the road the who exhaust. would it be alright and worth it to do 1 part now and 1 later on, or just get them all at once?
Old Apr 21, 2009 | 01:28 PM
MikeGrote's Avatar
500 bucks, geez, are there any cheaper ones? have these been flow tested compared to stock?
i think the HR Ypipe would be a better upgrade until i see some hfc flow numbers better than stock
Old Apr 22, 2009 | 11:38 AM
crazeejitt's Avatar
any other advice?
Old Apr 22, 2009 | 01:41 PM
tiguy99's Avatar
Have you looked into other brands? Search. I have the Berk HFCs and love them. I certainly didn't pay 500 for them. Try about 30% less and they were brand new too
With the stock exhaust and the HR Y pipe, the sound is sex
Old Apr 22, 2009 | 02:16 PM
gabe3d's Avatar
A specialty shop in the bay area called Zcargarage has done numerous before and after test with dynos and it apparently shows significant gains. If you go to their site and look at their blogs, you will find it. Not to say that it is better then other HFC but over stock, it is without a doubt better. I personally run Test Pipes.
Old Apr 22, 2009 | 03:10 PM
MikeGrote's Avatar
thanks, ill check that out. the stockers must be awefully restrictive then.
Old Apr 22, 2009 | 03:14 PM
MikeGrote's Avatar
hey, could you post a sound clip or pm me one? thats exactly what i want to do. i think the HR Ypipe is a great idea cause it extends the length that there are dual pipes. that will help for power. and if i can find a flow test showing HFC are significantly better than stock, i would consider those. but, i dont like how loud all the aftermarket exhaust system are, so no catback for me
edit: could you also look to see if that new Ypipe hangs down any lower than your old one? im lowering and dont want that scraping if i got a new one, thanks
Th611
Oct 27, 2015 03:48 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
derres
Aug 28, 2015 03:27 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
