"Ring" is important?
Old Aug 21, 2009 | 03:26 PM
drifts500's Avatar
I am talking about ring between Y-pipe to End muffler
I forgot to bring the ring to the shop, so they installed stock exhaust without
the ring. Does it affect anything?
I hope I do not have to go to the shop again
Old Aug 21, 2009 | 04:48 PM
waijai's Avatar
i.love.gold
The gasket is there to prevent exhaust leaks. Drive for a week and see if there are any sooty, black marks around the flanges. If so then you have a leak.
Old Aug 21, 2009 | 06:00 PM
drifts500's Avatar
^ Thanks, so it does not affect any performance or sound right?..I will check if it leaks
Old Aug 21, 2009 | 06:16 PM
binder's Avatar
If you have a leak it could cause a sound problem. Sometimes a hiss, sometimes a tick.
Even if it doesn't make noise, it probably would be a good idea to run a gasket.
Old Aug 21, 2009 | 06:40 PM
drifts500's Avatar
There was hiss sound when I bought the car. Around 1.5~2k rpm.
I will drive this week and do something. I hope the shop does not charge more than $20..
Or I can just do DIY..Oh I check the muffler and then I think the shop put used gasket in the back section instead of ring.
Old Aug 22, 2009 | 09:14 AM
binder's Avatar
Most shops will have gaskets in stock hanging on the wall. I'm sure they put one back in it.
Old Aug 22, 2009 | 11:12 AM
Texasscout's Avatar
I can't belive that any good exhaust shop would put it together without SOME KIND of gasket. Just call them.
wow600rr
Sep 28, 2015 11:50 AM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
wayneside
NorthWest
Sep 23, 2015 06:24 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
