Rev up lower plenum.. Will it benefit non rev ups?
Old Aug 24, 2009 | 10:27 PM
officerdbag's Avatar
Anyone know if a lower plenum off a Revup motor will beneift the non revup? I know the lower plenum from a non revup will give gains to a revup motor but how about vice versa?
Old Aug 25, 2009 | 02:14 AM
Hydrazine's Avatar
It sucks bad. I've seen the dynos.
It loses power everywhere except the last ~600 RPM.
Just put a spacer on your nonrevup lower collector and you will be much better off.
Old Aug 25, 2009 | 02:19 AM
Really? Thats good to know.. I'm actually looking forward to the 5/16th for the torque. I have enough top end.. Weird though, makes you wonder why nissan made a crappy newer lower plenum
03threefiftyz's Avatar
Can I link to the 1cockyz build on my350 or will that get me banned? I recommend you hop on there, search his created threads, go to his build, and do some reading. It will show you unequivocally the benefits of the non-rev plenum. With that said I agree with Hydrazine.
Old Aug 25, 2009 | 09:01 AM
DaveB's Avatar
The Revup plenum was matched to the higher flow and revving characteristics of the Revup motor which can rev 600rpms higher than the regular VQ35DE. Essentially the Revup plenum uses shorter intake runners to improve higher rpm breathing above 5000rpms. The problem is the shorter runner nueter low and mid range power. Due to slight variations in cam design and the usage of variable timing on exhaust cam, the Revup can utilize the revised plenum a bit better than the VQ35DE.
Old Aug 25, 2009 | 11:50 AM
Hydrazine's Avatar
Originally Posted by 03threefiftyz
Can I link to the 1cockyz build on my350 or will that get me banned? ...
I can't imagine why it would be a problem. I post links to MY350Z all the time.
Both sites are owned by I.B..
Old Aug 25, 2009 | 12:24 PM
http://my350z.com/forum/na-builds/40...d-build-6.html
1st post on that page. Shows Tony's point quite clearly.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
