Installed the exhaust.. now TWANGing WTF
Old Feb 10, 2010 | 10:33 PM
SedanManBen's Avatar
So I got the strup test pipes, nismo y-pipe, new coupe midpipe, and HKS sport muffler on today... sounds PHENOMENAL... but I've always had a problem with the exhaust "TWANG" ing.... it's always done this... it sounds kind of like a heat shield is vibrating or something. When I just had the coupe middy on... it seemed to only do it at about 1500-2000 RPM... and it sounded like a blown baffle in the stock muffler. I tried bending the heat shield around the middy... no fix. Now, with an ENTIRELY new exhaust system... its WORSE... what the hell could it possibly be?
VIDEO***listen when I give it a little gas
Old Feb 10, 2010 | 10:57 PM
AARONHL's Avatar
Sounds like that RICEY "bees in a can" sound!!! Double check to see if all connections are not leaking???
Old Feb 10, 2010 | 11:00 PM
I made sure there's no leaks and all that good stuff... the problem is that it's the SAME twanging sound I've been getting for quite awhile now... even with the bone stock exhaust and the added coupe middy
Old Feb 10, 2010 | 11:01 PM
AARONHL's Avatar
I see, could you pin-point what section of the car?
Old Feb 10, 2010 | 11:10 PM
It's hard when I'm by myself :-/ but when troubleshooting the problem previously with friends it sounded like it was coming from around the rear muffler section.
I've had a suggestion that it's rasp from test pipes? i really hope not... or else I'll be looking for HFC immediately
Old Feb 10, 2010 | 11:15 PM
SxExCx's Avatar
That is what's referred to as "rasp" which is caused by the unrestricted flow of exhaust and unburned fuel. It is most commonly caused by the test pipes. It usually doesnt happen with a stock system so you probably had something loose before.
Old Feb 10, 2010 | 11:22 PM
Hey everyone look at me.. huge dummy.
Old Feb 10, 2010 | 11:32 PM
Jairen's Avatar
Test pipes.
Old Feb 11, 2010 | 08:46 AM
Well I guess there's only one way to learn these sorts of things... at least everyone's respectful and not as5hats when it comes to my newbish ways
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
