3 inch filter causing stuttering, help please
Old Feb 13, 2010 | 10:08 PM
brandonbeeb's Avatar
hey hoping you guys can help me out, i have an 04 g35 coupe, have a z tube on it and i picked up a 3 inch filter today with the adapter to bolt it up to my maf sensor. the problem is when i installed it the car hesitates like its stuttering, checked all the connections and what not and everything seems good, any ideas?
thanks
Old Feb 13, 2010 | 10:16 PM
Deepdiver's Avatar
what??
Old Feb 13, 2010 | 10:24 PM
officerdbag's Avatar
Vacuum leak? MAF sensor in there all clean and secure?
Old Feb 13, 2010 | 10:49 PM
put the factory box back on and it's fine. even a litle leak shouldn't cause an issue. any other ideas?
Old Feb 13, 2010 | 10:53 PM
Did you get any check engine lights? Reset the ECU.
Old Feb 13, 2010 | 11:00 PM
kennymo's Avatar
what kinda filter is it? sounds like the filter is a POS and is not letting enough air in
Old Feb 14, 2010 | 01:40 AM
its a ractive filter, do you think this is the problem, before it gets to the filter it goes into a square as you can see in the pics, im thinking it needs to be fully opened up 3 to the full 3 inch like the factory one?
Old Feb 14, 2010 | 02:01 AM
KSWAY's Avatar
WTF? why would you want that?
Old Feb 14, 2010 | 02:31 AM
if it was like this do you think it would solve the problem
Old Feb 14, 2010 | 02:49 AM
Deepdiver's Avatar
Old Feb 14, 2010 | 12:33 PM
PTownG's Avatar
What is that around the square? did you attempt to seal what is obviously not made for your application with silicone?
Fail.
Old Feb 14, 2010 | 02:34 PM
kennymo's Avatar
honestly i would just get a different filter
Old Feb 14, 2010 | 02:50 PM
Thats a terrible filter/set up
jilljann1
Jul 21, 2020 08:12 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
cmesidewayz
Sep 29, 2015 09:28 PM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
JG_G35
Sep 7, 2015 09:35 PM
