Question about G35 Extension & Nismo
Old Jun 9, 2010 | 10:29 PM
bobruggiero's Avatar
Okay so I was installing my nismo today and came across something. I had bought 2 extension pieces (knowing I only needed one) from someone locally. They said they bought from mynismo.com. The thing is, I've read that the extension piece goes between the Y pipe and the midpipe. The one's I receieved make the exhaust fit fine. However, 2 are needed because the flanges arent wide enough to fit the nismo exhaust between the midpipe and the y pipe. So...here's the deal. Right now, I'm waiting on my nismo y pipe...so I installed the nismo exhuast with the stock y pipe. It goes stock cats-g35 extension pieces on both sides-y pipe-midpipe-muffler.
Will this work okay, will it alter the sound or affect performance any? I mean the exhaust fits okay, sounds quiet-which I assume will be remiedied when I get the nismo y pipe..but I'd appreciate some help with my questions here.
Summary:
1.) Location of G35 Extensions-will this work okay?
2.) Will replacing the stock G35 y pipe with the nismo y pipe alter the sound with the Nismo Exhaust.
Thanks very much in advance.
Old Jun 10, 2010 | 12:23 PM
LightsOut's Avatar
SIETESG
1. it will work, but you should put them where they belong.
2. Y pipe isn't going to change the sound very much. you'll notice the sound change at start up but then it will fade to stock again.
Old Jun 11, 2010 | 04:21 PM
Okay so its fine for a while to keep those 2 extensions? And darn I was hoping it might be a little louder with the nismo y
Old Jun 11, 2010 | 05:45 PM
LightsOut's Avatar
SIETESG
you'll be find, but if you feel your car lagging.. just check for an exhaust leak, cause I doubt you put gaskets at both ends of the extentions?
Nismo Y would be a little louder.. but dont expect it to be the difference maker.
Old Jun 11, 2010 | 05:59 PM
Yeah I put gaskets in...I do have a small leak near the muffler but I doubt that will make a difference so far away from the engine
Old Oct 7, 2010 | 01:12 PM
g35sweetness's Avatar
Old Oct 7, 2010 | 01:13 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Kz_Ed
Jul 23, 2015 02:41 AM
