Delete Y-back system Rasp?
Old Sep 4, 2010 | 04:34 PM
SkylineGTR2789's Avatar
Hey guys, I recently just got a y-back (Midpipe + Muffler) installed on my car .. I like it a lot. It's really deep below 2k RPM but when you push the pedal down I get a raspy kind of sound.
the midpipe is 3" and the tips is 4" in diameter. I was wondering if I added a 3" Y pipe. Would that fix the problem ?
Here's a video.
Old Sep 4, 2010 | 05:10 PM
doeboy's Avatar
It sounds decent to me, hard to hear the rasp over the music in the video though
Old Sep 5, 2010 | 01:10 AM
Yea sorry about the music .. Ill try to get a better fly by video later.. but idk .. it has this tin can kind of sound past 3.5k rpm n then it goes away (from what I can hear inside) after about 5.5k RPM
Old Sep 5, 2010 | 11:14 AM
bump
Old Sep 5, 2010 | 03:52 PM
Bump ttt
Old Sep 5, 2010 | 03:57 PM
Jairen's Avatar
To reduce rasp, you'll need the Motordyne XYZ y-pipe with resonator. More power and less rasp.
Old Sep 5, 2010 | 09:41 PM
Massios's Avatar
Resonators cut rasp, either add one to your custom mid pipe, or pick up/build a y pipe with a resonator.
Old Sep 6, 2010 | 12:14 AM
does this have a resonator ?
http://www.hopupracing.com/apsevvihiout.html
Sorry if its a dumb question
Old Sep 6, 2010 | 04:37 PM
bump
Old Sep 7, 2010 | 11:56 AM
ttt bump
Old Sep 7, 2010 | 12:02 PM
LightsOut's Avatar
SIETESG
no it doesn't.
those are flex joints. A resonator is a tube looking muffler. Just drive down to your local muffler shop, tell them install a 8-10 inch magnaflow resonator on the mid pipe. it will reduce the rasp.
Also remember too that if the exhaust is new, it takes a while for break in time and rasp will reduce.
Old Sep 7, 2010 | 12:04 PM
jayk's Avatar
NO.
this is what you need. MotorDyne XYZ with Resonator as stated above.
www.motordyneengineering.com
stop bumping.
Old Sep 7, 2010 | 12:46 PM
Originally Posted by LightsOut
no it doesn't.
thanks for the suggestion I may go this route
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
04G35NYC
Winter Setups
34
Jun 2, 2016 09:12 AM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
BradMD_96
Oct 6, 2015 09:31 AM
