Kinetix v+ plenum: Please help! Idk why its doesnt this!
Feb 9, 2011 | 12:28 PM
hi, i just purchased the Kinetix V+ plenum for my 2004 g35coupe 6mt. when i was installing i was reading the directions as i installed it and went step by step and connected all the hoses and everything back up as the directions stated.
then double checked.
when my started my car up, the check engine light came on and now the rpm's wont rev past 2,300 even when i drive.. when i try to go past 2,300 rpm's the car just revs over and over in the same rpm range between 2000 and 2500rpm's and the car shakes. and when i start it up it almost sounds like its not gonna start because it idles really low like its gonna cut off then it starts to get normal after a few seconds. pleaase help.
Reply 0
Feb 9, 2011 | 12:30 PM
connect the maf connector?
Or did you disconnect the TB? You might have to perform the idle relearn
Reply 0
Feb 10, 2011 | 01:46 PM
yeah make sure your TB sensor is plugged in. Reset ECU also.
Reply 0
Feb 11, 2011 | 12:39 AM
i did all the above and its still in limp mode... i did the ecu reset from technosquare and did it perfectly and when i started the car after the check engine light is supposed to go off, it came back on
Reply 0
