Berk HFC rasp?? :(
Old Mar 7, 2011 | 03:01 AM
xfuz1on's Avatar
Berk HFC rasp?? :(
So I recently purchased Berk HFC from a fellow member to pair with my Stillen TD Exhaust. The HFC were in mint condition and I heard his setup right before he took off his HFC with no rasp. However, upon installing the Berks paired with my nismo, my car would rasp around 3.5k~5k under 1/2 throttle . What could be the problem? It's bugging me . Any help is appreciated and thanks in advance!
Old Mar 7, 2011 | 03:19 AM
chink-ah-saur's Avatar
Did you use new gaskets???..but wtf some ppl say rasp others say sex so idk
Old Mar 7, 2011 | 12:01 PM
xfuz1on's Avatar
speaking of that ... haha probably not. I went to a shop in the OC where I met up with a fellow member and we just did a straight swap. Can that be the reason why it rasps? If so, what type of gaskets should I get?
Old Mar 7, 2011 | 12:04 PM
Oem ones $40 or just any kind of new ones.. But someone stated oe ones work the best
Old Mar 7, 2011 | 12:05 PM
xfuz1on's Avatar
So used gaskets are normally the cause of rasp? I believe they were fairly new still too. Only had ~4,500 miles on them
Rasp or hissss sound..i think the gaskets were to help hiss but you can give it a shot
Old Mar 7, 2011 | 12:07 PM
xfuz1on's Avatar
Mine doesn't hiss, it rasps =[ .. If that doesn't work, there goes $$ down the drain :/
Old Mar 7, 2011 | 12:10 PM
Hope you can figer it out if not and you want to sell..pm me
Old Mar 7, 2011 | 07:33 PM
gary c's Avatar
If you have the hiss after installing HFCs it's due to poor quality gaskets or installing them incorrectly. If you need new gaskets get the OE from Nissan, make sure you match them up cause Nissan has the wrong info in their system. Rasp isn't caused by the addition of HFCs, they've just enhanced what was always there in your aftermarket exhaust system. Love my BERK'S with my HKS exhaust although I will be substituting the MAGNAFLOW crossover (x-pipe) just because it's a better mixer or crossover than the old school H pipe and worth a few HP!
Gary
Old Mar 7, 2011 | 07:45 PM
xfuz1on's Avatar
So how would I get rid of the rasp then? I never heard rasp with my stillen exhaust prior to the install of the hfc.
Old Mar 7, 2011 | 07:54 PM
1trueG's Avatar
Try new gaskets like suggested above....
Old Mar 7, 2011 | 07:56 PM
xfuz1on's Avatar
Uh .. Well Gary said if it hisses, try new gaskets . Mine doesn't hiss, it RASPSSS ! I sound like a Honda civic :/
Old Mar 7, 2011 | 07:57 PM
gary c's Avatar
Which Stillen exhaust do you have the real dual or the OE style single made by Magnaflow? This is a question you should ask Stillen, although they're nice people doubt they'll have an answer for you. You may have to live with what you have or buy a new exhaust system which is costly....I've had five different systems on my coupe luckily two were sponsored.
Gary
Old Mar 7, 2011 | 08:00 PM
xfuz1on's Avatar
I got the real dual exhaust
Old Mar 7, 2011 | 08:17 PM
gary c's Avatar
That's a good exhaust system, and my second. For the best advice and since you live in SoCal give my muffler guy a call 661-259-7098 his name is Dean and very knowledgeable. He's here in Valencia and open on Saturdays by appointment.
Gary
