custom exhaust build question
Old Jun 15, 2011 | 06:51 PM
jinc1026's Avatar
I am planning to make a custom exhaust
and I wanna make it true dual using magnaflow's muffler(11385) which is
dual in/out (2.25in).
The question is I could found the muffler on the website, but where do I get
2.25 inch piping from??
Should i just buy this muffler and bring it to any custom exhaust shops?
Old Jun 15, 2011 | 06:58 PM
Jeff92se's Avatar
Red Card Crew
If you aren't actually welding up the system yourself, you can just ask the shop to provide you with whatever size pipe you want. I'd prefer mandrel bent and SS if you can afford it. But non-SS is probably okay for your area. If you are making a true dual, then I'd definately use two of the above and use one of them as a resonated X pipe right after each cat.
Old Jun 15, 2011 | 11:57 PM
sukh79's Avatar
Hey Jeff...question...wrong thread but I've read a few of your other exhaust posts...I have all breather mods plus cams.and springs w tune...i have a 2.5 td ingen...am I better off with this setup or a single 3" pipe with hr y pipe and OEM style muffler.
Old Jun 16, 2011 | 03:05 AM
Jeff92se's Avatar
Red Card Crew
Just in my opinion only. Hydrazine really likes his Y pipe design coupled to a pretty big arsed pipe coming out of his merge collector. I think he makes a 3" single exhaust. but he's careful to make sure his Y pipe design maintains as much torque/hp as possible.
I know the Motordyne stuff really flows. How much better than a HR Y and Ingen, I don't know. But the motordyne stuff is probably the best out there. Not cheap though
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
