Just bought a OEM Z Tube
Aug 22, 2011 | 05:40 PM
I bought a OEM Z tube for my 03 G Sedan, however I noticed
it's all Rubber and it's missing the clamps on both sides.
The metal part that goes around the tube, Both Sides.
I believe its the throttle connection, and the other side is the air filter box connection.
When I take off the Stock Tube can I use those connectors / clamps?
Thanks, Never done any of this stuff before.
Reply 0
Aug 22, 2011 | 05:52 PM
I'm pretty sure u can use the clamps that are presently on ur car now.
It's plug n play.
Reply 1
Aug 22, 2011 | 05:53 PM
Here's a DIY.
http://www.6mt.net/mod-g35-350z-intake.php
Reply 1
Sep 12, 2011 | 09:41 AM
The one clamp from the G near the TB has a different set hole than the Z. I think the Z clamp has a triangle hole. You can use it, you just should cut off that piece of rubber sticking up and it will be fine.
Reply 0
