Video: X02 exhaust with magnaflow x pipe (stock cats)
Old Oct 15, 2011 | 09:22 PM
antodiaz's Avatar
X02 exhaust with magnaflow xpipe and stock cats. I love the sound absolutely no drone or rasp. For $430 is a great deal and you'll get some descent power. I went from a 9.7 to a 9.3 on the 1/8 mile with this exhaust.
http://http://m.youtube.com/index?desktop_uri=%2F&gl=US#/watch?v=tTXI9ACPjmk
And the rattle is the damn ACT flywheel that I hate. Im taking it to the mechanic next week because its a little louder than normal.
Old Oct 15, 2011 | 10:07 PM
Massios's Avatar
Sounds great man. Its amazing what a few resonators will do.
Edit:
Fix't
Old Oct 15, 2011 | 10:12 PM
antodiaz's Avatar
Thanks man! I didnt know how to post it like that...
Old Oct 16, 2011 | 11:02 AM
Massios's Avatar
Quick question. Is that that the resonated X pipe or non resonated?
I have the non resonated on my 60mm custom dual exhaust, with no other resonators. I do have high rpm rasp, but you have none.
Old Oct 16, 2011 | 01:22 PM
antodiaz's Avatar
It is a resonated x pipe. Its nice because unless you are at full throttle you can barely hear it.
Old Oct 16, 2011 | 04:51 PM
Jbarag0131's Avatar
Did the exhaust fit right ? Because I know those x02's don't always fit so well. Also where did you find that exhaust and x pipe ?
Old Oct 16, 2011 | 06:36 PM
antodiaz's Avatar
Well the right tip was a little to close to the bumper but the muffler shop took care of that. The exhaust I bought it on ebay and the x pipe from a member here. Exhaust ($280) x pipe ($50) all new.
Old Oct 20, 2011 | 04:59 PM
mikhaelbt189's Avatar
can you please tell me which x pipe u using? 2.25" or 2.5"? i need one but kinda confuse with these 2. some people here say to go with 2.25 but x02 or m2 are using 2.5" diameter...
Old Oct 20, 2011 | 07:55 PM
Massios's Avatar
The hks / x02 uses 2.5in diameter piping. You will want te 2.5 x pipe. Get the resonated one if you want to get rid of rasp.
Old Oct 20, 2011 | 09:03 PM
antodiaz's Avatar
^^^ totally right.
Old Oct 20, 2011 | 09:06 PM
can u post the pic of ur setup? like where u weld the magnaflow?
Old Oct 20, 2011 | 09:17 PM
ryanm8's Avatar
You'll want to pretty much weld it as far up on the Y-pipe as you can to get the most power. If you weld it say in the middle of the exhaust, you'll lose power.
Old Oct 20, 2011 | 09:31 PM
Massios's Avatar
You won't necessarily loose power by putting it further down the exhaust, however the main objective of an x pipe is to aid in exhaust pulse scavenging (ie: using pressure to pull the combusted fuel/air out of the cylinders)
With our set ups it is best to put the x pipe right as the y pipe turns the 45 to run down the transmission tunnel.
Old Oct 21, 2011 | 01:24 PM
hey guys, quick questions. how do you guys put ur x02 exhaust on G's? mine like test pipe>extender>ypipe. or is it supposed to be test pipe>ypipe>extender???? i got confused as many people do the extender after the y pipe?
Old Oct 22, 2011 | 10:23 PM
jinc1026's Avatar
i have a custom exhaust 2.25 inch pipe and im thkning about getting x pipe to get rid of drone
i should get 2.25 x pipe or 2.5 inch x pipe?
