HELP!! New exhaust set up is vibrating.....?
Old Jan 28, 2012 | 12:53 PM
ekrebs's Avatar
Hi guys i just installed my new exhaust set up on my 05 5at sedan.
The set up includes Ichiba y pipe, kinetix test pipe with resonators and megan cat back..
I hear and feel a vibration but i cant find out where. could it be hitting something or maybe the bolts are not tight enough?
Has anyone encountered a similar problem??
Old Jan 28, 2012 | 12:55 PM
Algy's Avatar
Check out the heat shields. That causes a lot of unwanted rattling vibration noises.
Old Jan 28, 2012 | 01:38 PM
ekrebs's Avatar
will do, should i just remove them or just bend them?
Old Jan 28, 2012 | 01:40 PM
ajkVQ's Avatar
as mentioned earlier, its probably the heat shields. does it happen only when its cold?
Old Jan 28, 2012 | 01:48 PM
ekrebs's Avatar
No it happens when im accelerating, after car is warm.
Old Jan 28, 2012 | 04:10 PM
05Scoobyroo's Avatar
Not sure if the sedans have this, but on the coupe, there is a "V" shaped brace that ties the both sides of the car together in the middle by the midpipe. When I installed my Fast Intentions before, the vibration that I found was the mid pipe hitting this. To fix, I just loosened up the exhaust flange bolts, applied upwards pressure on the pipe and and re-tightened the bolts.
Old Jan 28, 2012 | 05:07 PM
ekrebs's Avatar
So i figured out what the prob was. the driver side heat shield was hitting the test pipe so i removed it..
Now do you all think leaving it off is ok?
Thanks for the reply's..
Old Jan 29, 2012 | 08:32 PM
ekrebs's Avatar
So is it ok to leave heat shield off?
Old Jan 29, 2012 | 09:36 PM
ryanm8's Avatar
Should be fine.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
D1dphresh
Aug 7, 2015 06:10 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
BlackGee35
Jul 21, 2015 07:24 PM
