Header install - hissing
Old Jun 28, 2012 | 02:12 PM
Nismo G's Avatar
I searched around a little bit, but couldn't find anything. I read about a hissing noise after installing either test pipes or HFC, but nothing on headers.
I installed Strup headers a few weeks ago (factory cats) and when i rev the engine or the engine looses revs around 2000-3000rpm or 3000-2000rpm there is a hissing noise. Almost like air is trying to escaping, but it has no where to go. Has anyone else experienced this or heard of this after header install?
Old Jun 28, 2012 | 02:42 PM
jbwrecked's Avatar
Maybe the gaskets bad and you have a leak? Hopefully thats it..
I would go back and retighten everything, maybe try loosening it up and then retightening
Old Jun 28, 2012 | 04:16 PM
MaDMaXX's Avatar
Yeah, have you checked for leaks yet?
Old Jun 30, 2012 | 02:36 PM
Nismo G's Avatar
Checked for leaks...i don't see anything...
Old Jun 30, 2012 | 04:47 PM
Dsskyline's Avatar
Since you have a 03 did you use new gaskets? Wipe/clean connections that need a gasket, then take the car for hard drive or when the car is cold started look for water leaking at those flanges.
Check for carbon build up at the areas you just cleaned if you find any then you have a exhaust leak.
Old Jul 1, 2012 | 01:20 PM
Nismo G's Avatar
Yeah, all new gaskets. I don't see any leaks or water anywhere...
Old Jul 1, 2012 | 01:39 PM
Dsskyline's Avatar
The only thing left to do is look under car while someone revs to try and see where it's coming from.
One last thing to check is are your O2 sensors in tight? One may be loose.
Old Jul 1, 2012 | 09:38 PM
Nismo G's Avatar
lol we did that to. Put it on the lift where i used to work and the only thing we can determine is that it was coming from the cats...but we didn't see any leaks.
Old Jul 1, 2012 | 09:45 PM
Dubi2087's Avatar
If it sounds like a rattle snack hiss than it is your Y-pipe. The flex pipes go bad and start to hiss. It happen to me and my best friend both changed out our Y-pipes and noise was gone. If you don't want to replace your y-pipe try getting some heat wrap and wrapping the flex pipes.
Old Jul 1, 2012 | 09:59 PM
IS3_FTW's Avatar
the best thing to use is sea foam to see if its leaking anywhere
did you tighten each nut to specs? ive heard that if you tighten the crush gaskets to tight, then it could cause a leak. and by loosening and retightening, the gaskets will still be crushed from the 1st tightening. might need to get new crush gaskets if thats the case.
Old Jul 1, 2012 | 11:15 PM
Dsskyline's Avatar
Dont know what to tell you except take them off if you are sure it's from the cats.
Old Jul 1, 2012 | 11:37 PM
bluedevils95's Avatar
You installed them yourself? maybe you can take it to the shop to double check your work.
Old Jul 2, 2012 | 12:08 AM
seymore4's Avatar
m56
I'm sorry, I stopped reading at headers + factory cats... SMH
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
Machine Head
Sep 4, 2015 07:22 PM
linedr89
Aug 17, 2015 05:11 PM
yosip1115
Engine - Exhaust
Jul 22, 2015 01:47 PM
