PCV hose???? help please
Old Nov 2, 2012 | 01:54 AM
blkdout04's Avatar
Quick question,
I believe im looking for a PCV hose, but just want to confirm...
The rubber hose running to the underside of my intake was creased and now cracked and definitely leaks from the location. I want / need to replace this. Does anyone know if this is the hose im looking for, the PCV hose?
If any vendors have a hose kit that they sell that includes this, Im looking for one. Please let me know.
ill get a picture tomorrow if need be.
Old Nov 2, 2012 | 05:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
It's a vacuum hose but doesn't go to the PCV valve. I would remove it and take it to a local auto parts store to match it.
Old Nov 2, 2012 | 09:53 AM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
I talked a tech one time about that, if it's the one that goes into the intake and kind of disapears, he said that was the Brake Booster hose
Old Nov 2, 2012 | 10:53 AM
blkdout04's Avatar
Yeah i couldnt see where it went, just that its a thicker hose and runs to the underside of my intake.
Old Nov 2, 2012 | 12:17 PM
Blue Dream's Avatar
Good to know Phil, thanks for the correction.
Old Nov 2, 2012 | 02:09 PM
Shakuya88's Avatar
If it goes to the underside of the intake tube (before the throttle body as it sounds like) then that is e breather hose for the PVC system. When in vacuum crankcase pressure goes through the pcv and the breather prevents a vacuum from building up and causing issues. When under WOT the intake suction is what pulls the vapors out of the crankcase. Like someone earlier said go to and advance or and autozone and match up size and length and replace. It is important. Hope that helps.
Old Nov 2, 2012 | 03:20 PM
PREMIUM SPONSOR
Take a look at this pic
http://grubbsinfinitiparts.com/nissa...5/J118007R.jpg
part code 11823+B
that's the hose coming off the PCV valve, not sure if it's what you are looking for or not
Old Nov 2, 2012 | 08:50 PM
blkdout04's Avatar
I got it thanks for all the help guys.
Phil, it was the 11823 (not +B) that i was looking for. I am now saving that diagram lol. Thank you for that.
NailBomb
Oct 28, 2015 07:53 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
G35CO
Sep 4, 2015 09:27 AM
