Going to try and install my Skunk2 Spacer
Old Jan 24, 2013 | 07:04 PM
CannonGentry's Avatar
Whats up guys, this weekend I'm going to attempt to install my Skunk2 Spacer on my G. I'm 16 years old but I've done some work on my old vehicle. I installed a throttle body spacer, new throttle body and a cold air intake. I'm not a complete clueless teenager, I'm pretty good at figuring stuff out and I actually enjoy doing these kind of things. I will have my step dad helping me, he's good a working on stuff. He replaced the whole front end on my Chevy. I've also watched a video on YouTube about a spacer install on a g35 & it didn't look that difficult.
I'm just wanting to know if the spacer is difficult to install and is there anything I should be careful with & is there anything special I need? I think I remember hearing about a fuel line adapter or something.
Thanks
Old Jan 24, 2013 | 07:52 PM
terrorx7's Avatar
Thanks
I'm assuming you're talking about the plenum spacer? Piece of cake...take your time and don't pinch the oil filler rubber gasket as this seem to be the most common problem. There's no fuel line adapter or anything to do with the fuel line...you may be referring to the throttle body coolant line?
Old Jan 24, 2013 | 09:12 PM
Yes the plenum spacer. I just wanted to hear something positive about it. Thanks for your tip. & maybe im just thinking of something else about the fuel line lol. Hopefully everything goes good. Thanks!
Old Jan 24, 2013 | 11:44 PM
mikhaelbt189's Avatar
and one more thing, NEVER EVER touch the throttle body butterfly so you dont have to hassle with pedal relearn procedure stuff.
Old Jan 25, 2013 | 03:44 AM
dexthurr21's Avatar
just follow the DIY, you'll be fine and just remember to torque it correctly.
Old Jan 25, 2013 | 04:05 PM
bigc's Avatar
Wings Nation
+1, and be sure to rent an inch-lbs torque wrench if you don't already own one.
Old Jan 27, 2013 | 09:05 PM
I did it last night & everything worked out great and my plenum spacer is successfully installed! Btw I took the throttle body off, played with it wot and everything. Put it back together and everything is still fine. I think the trouble everyone has with tb's is that they don't disconnect their battery. But everything is fine on my car & thanks for all of y'all's tips! Helped me a lot!
jsimonk
Dec 22, 2023 03:49 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
