Y pipe bolts fell out of flange, what size and where to buy?
Old Dec 14, 2014 | 04:46 PM
epborden's Avatar
Well the bolts on my y pipe to cat flange on one side have gone... missing. They must have been loose front the installer and progressively gotten more loose until they just fell out! Does anyone know the size of these bolt/nuts and how I can get two more and a gasket??
Old Dec 14, 2014 | 08:05 PM
epborden's Avatar
I did some research and came up with a temporary solution until I get to the shop. If anyone happens to have this happen to them this is what you could use. If you're just trying to get to the shop forget the gasket. Pick up some M10x1.25 OR M10x1.50 35MM or greater bolt and nut in same thread size (1.25 or 1.50) and bolt up your parts. You'll create a good enough seal as to be able to make it to the shop and get a proper fix, if you don't have the ability to do it otherwise.
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
