A/F,HO2, and O2 Sensors?
Old Nov 22, 2017 | 03:33 AM
RA122223's Avatar
Hello everyone! I just signed up for this forum and will post my 2004 G35 ASAP on the new members page. I just bought this car the other day and it had a few minor (or so I thought) problems with it. The guy I got it off of said that the O2 sensors was bad and that was the reason for my Service Engine light to be on. I left my OBD monitor at home like an idiot and believed him. Well I took it home and scanned it and it said that I have 6 pending error codes. The car has no problem with idling but it does have a little backfire after I let off the throttle. Kinda sounds like little pops, not that loud.
P1148 - Closed Loop Control Function 1
https://www.autocodes.com/p1148_infiniti.html
P1168 - Closed Loop Control Function 2
https://www.autocodes.com/p1168_infiniti.html
P1031 - Air Fuel Ratio Sensor 1 Heater Control Circuit Low Bank 1
https://www.autocodes.com/p1031_infiniti.html
P1051 - Air Fuel Ratio Sensor 1 Heater Control Circuit Low Bank 2
https://www.autocodes.com/p1051_infiniti.html
P0057 - HO2S Heater Control Circuit Low Bank 2 Sensor 2
https://www.autocodes.com/p0057.html
P0037 - HO2S12 Heater Control Circuit Low
https://www.autocodes.com/p0037_infiniti.html
I was just planning on buying two O2(
Amazon Amazon
) sensors hoping that it would fix the problem but I saw this forum and thought I would ask the community first.
Thanks to anyone who can help me! Also, if there are better sensors out there, please recommend them to me because I'm fairly new to this.
Old Nov 22, 2017 | 09:53 AM
yosip1115's Avatar
Don't buy the sensors yet. There are fuses behind the battery that regulate the o2 sensor heating for all four sensors... If heating goes out, closed loop errors will come up.
That'd be my guess. Let us know if you find a popped fuse. If it keeps popping check the o2 wiring for shorts
Old Nov 23, 2017 | 02:01 AM
RA122223's Avatar
Thanks so much for the reply man! I just checked my fuses and saw that the owner before me actually put the fuse in the wrong slot. I cleared the code and tired driving around for a bit, it still pops a little but the light hasn't come back. I keep this post updated if it does.
Old Nov 23, 2017 | 11:46 AM
yosip1115's Avatar
I'm very glad to have helped a bit!
Check that wiring, narrow it down! (Unless you mean the exhaust is popping, not the fuse, then try the ecu reset, throttle pedal and throttle body/idle relearn procedure)
Old Nov 24, 2017 | 12:54 AM
coffeysm's Avatar
You might have to reset your fuel trims or just keep driving it around and it should balance itself out.
Old Feb 11, 2024 | 04:40 PM
dahomietaz's Avatar
2007 G35X (VQ35HR) FBO Tuned
BrodieG35
Intake & Exhaust
Sep 30, 2021 10:42 PM
Blacked_out_G35
Feb 4, 2016 06:31 PM
WxAxGxS
Dec 30, 2012 07:08 PM
psycobusa
Jun 13, 2011 02:50 PM
Theory_EK
May 3, 2010 02:35 PM
