pop-charger question..?
Old Jun 15, 2005 | 09:35 PM
mll20's Avatar
Can i install a pop charger with out a z tube or do i need to get both?..Thanks ahead.....
Old Jun 15, 2005 | 09:47 PM
BlackonBlackG35's Avatar
you can, but it wont be as loud, which is basically the only benefit of the pop charger anyways....
Old Jun 15, 2005 | 09:51 PM
codeflux's Avatar
why would you want to? get both. they are cheap. to answer your question, i don't think it'll work. /edit or maybe it will.
Old Jun 15, 2005 | 10:19 PM
lowrider's Avatar
The answer to your question is yes. However, if I were to do only one, it would be the "Z" tube, before the POPCharger.
BTW, I have both.
Lou
Old Jun 15, 2005 | 10:27 PM
mll20's Avatar
thank guys ....
Old Sep 10, 2005 | 09:19 PM
Hooman6MT's Avatar
20 Year Member
is a pop charger any old cone shaped intake filter? I have a injen CAI made for a Auto that was given to me for free. Can I just buy a z-tube and use that filter?
Hooman
Old Sep 10, 2005 | 11:36 PM
Jtrain's Avatar
Yep
Old Sep 10, 2005 | 11:38 PM
MBentley's Avatar
I've got just the pop charger on my car now. I got it at a good price. Saving up for the tube. Sound is beautiful. I can't wait to get the tube on there.
EricIsKlumzyee's Avatar
pop charger = big *** filter that sucks alot of air
Old Sep 11, 2005 | 01:32 AM
Hooman6MT's Avatar
20 Year Member
How big is big? 3 inch, 3.5 inch, 4 inch?
Hooman
Old Dec 23, 2007 | 04:29 AM
Dem1K's Avatar
figured I'd bump this up...I swear I've searched and read over 50 different threads and not one mentioned the size of the popcharger filter. Again, like they asked above, is the popcharger basically just the cone shaped filter, which is similar to any other aftermarket intake? I also have a spare intake from my prelude which had a cone filter, and wondered if I could throw that on, since I just installed the Z-tube. I believe it is a 3" filter btw. Thanks for the input.
`John
Old Dec 23, 2007 | 10:47 AM
sloppymax's Avatar
`John
The inlet of the popcharger is larger, id guess 4.5"-5". If you want to reuse that 3" filter then you need to find a maf adapter for a Z, G35, etc. Then you could mount it directly to the maf tube but I would suggest coming up with some kind of heat shield.
Old Dec 23, 2007 | 07:53 PM
EuG35's Avatar
It's diameter at the widest point is 6 inches.
Old Apr 10, 2008 | 02:27 AM
Agent F's Avatar
I have a follow up question for this thread. Would a JWT pop charger off a Z mount right on a G?
Old Apr 10, 2008 | 02:38 AM
Jeff92se's Avatar
Red Card Crew
Yes it will fit. Might need to fiddle with a bracket but other than that, it should bolt right up.
I got my Stillen intake from a guy with a FX35. lol
