G35c Cold-Air
Re: G35c Cold-Air
It may be a part of the maxima engine but it has to fit in the coupe's engine bay so I am not sure how similar they are in that regards. In any case, there are intakes being made by stillen and others. Keep a lookout as many things are coming for the 350Z which should easily be fitted for the coupe. (Example: Power Enterprise's TT setup (est. 600+ HP) which you would have to change a good amount of your internals I'm assuming although the turbo kit alone is ~5000) [rumor from forums and website (http://godspeed.hack.net/PE.html )]
OvaYahead
16
Jan 27, 2003 11:31 AM
